thinking of upgrading my clutch and flywheel
i was wondering would getting a fidanza flywheel be unecessary for my setup as of right now. I currently have I/E/H and i need to upgrade my clutch so i was considering of upgrading my flywheel while i was down there. Good or not good.
Re: thinking of upgrading my clutch and flywheel
Upgrading your flywheel will be fine. I just put in an Exedy OEM replacement and an Exedy 9.5lb flywheel. I like it a lot.. people have said that light flywheels are hard to get the car moving with and that RPM's drop really fast, but it's not hard at all to drive with. Whoever says those things just must be really bad drivers.. But no, it won't hurt anything and I'm sure you'll like it. Besides you might as well do it while you're changing the clutch.
Since you have just basic I/H/E, just go with either the Exedy OEM replacement or a Stage 1 from another reputable company. Anything more is kind of overkill for basic stuff like that. You could get away with a Stage 2, but anything higher, I wouldn't recommend.
from what i know,anything less then 10lbs hurt driveabilty.. 10lbs and less is used for road course and constant high rpm racing... not if your at the track ( dead stop ) the extra light weight had less inertia.. example..at idel your flywheel rotates between 500-750rpms. the light weight makes it harder to move off from a stop ( causes a bogging feeling ). same happens at 2500 launch... ect.
a light weight flywheel is a great upgrade... better accelration is noticed. as well as less driveabilty... i wouldnt recomend a flywheel less the 10lbs for a daily driver, or unless you do road course were the engine is in constant high rpm.
but its your dessision. just my .02
Your car will buck more when you let your foot off the ground and coasting in gear wont get you as far. Not sure if lightweight flywheel will kill more gas mileage but i think it will.
OEM is 18 pounds right? i think that is too heavy, maybe something something like 13 or 14 would be good but those dont seem too common.
exedy stage 1 is the way to go. stiffer pedal + lower engagement over stock. and it engages real smooth unlike those 6 puck clutches
ya i drove an integra with a stage 2 clutch, not sure how much that weighs but it is very easy i love it better than stock, i want one now
i was looking at ebay and i could get a exedy oem replacement and fidanza flywheel for about 300$. I know the clutch is find but is the flywheel too light for my setup. Keep in mind guys that i do hope to one day build my head but that will be later in the future.
less rotaional mass on the engine...faster accelration throught the rpms. a little less load. faster engine decelration aswell...
there not "myths" its third grade science..remember the rope with the weight at the end..the light one was harder to get swinging...the heaver one was alot easier ... inertica... " abilty for a mass in motion to stay in motion "
the lighter the flywheel the higher your rpms raise at a faster rate, they also drop at a faster rate. It doesnt make the car stall more or less. You not knowing how to use your clutch and pre gass/balancing the clutch properly results that. Light flywheel makes less stress on everything to turn it, gives more response when needed and keeps it.
If your losing power torque and or anything else it isnt going to come from the flywheel being faster or lighter or heavier its because your still driving the car like you were when you had everything stock. Upon change of parts liek these you adjust your driving too because EVERYTHING changes. The flywheel is still doing its job, this part doesnt change it just simply does it faster in both directions downshifting and upshifting. You just need to adjust how you drive, obviously its going to change, thats like anything clearly.
^installing a lighter flywheel DOES make it easier to stall the car. the flywheel now has less inertia, and letting off the throttle at low rpm or not pressing the throttle hard enough makes stalling more likely.
I have an act street lite and act stage 1 clutch. There really was no real difference in driveability. the rpms would fall a little quicker but just noticeable if at all. I wish i got the pro lite.
i have an exedy flywheel in my gsr and shifting at lower rpm (3-4k) is a pita because of how fast the rpm drop. i didn't mind it at first but it got annoying after a while. also, it seemed to kill the low-end torque. my stock si feels like it has 2x the torque of the gsr. i wouldn't recommend a flywheel that light.
If the person knows how to drive a manual, they won't stall it. I still have yet to stall on this 9.5lb flywheel and I basically learned how to really drive a 5 speed with it after I did the auto->manual swap. So if they made it so much easier to stall out, then I would have since I was basically a beginner at that time. What you say is true, but it's really not that significant of a difference(stalling out) as compared to a heavier flywheel as to where it would be a "problem" for most people.
