Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Acura Integra (https://honda-tech.com/forums/acura-integra-6/)
-   -   oil light on (https://honda-tech.com/forums/acura-integra-6/oil-light-2189122/)
95_red_dc Jan 2, 2008 02:26 PM
oil light on
I was Driving my 95 teg on the highway yesterday and all of a sudden my oil light starts to flash! So I pull over check the oil and its full. The light does not come on till operating temperature and at idle it stays on but above idle the oil light will flash. What is wrong with my car it does not even have 80,000 miles on it yet
DOHCgarage919 Jan 2, 2008 02:34 PM
Re: oil light on (95_red_dc)
maybe time to change your oil?
IamPhil Jan 2, 2008 02:37 PM
You could still be low on oil, I was taught to check the dip stick when the engine gets to cool since heat expands.
thewrai6th Jan 2, 2008 02:38 PM
Re: oil light on (DOHCgarage919)
I would check in this order
1 Lack of oil
2 Bad connection to sensor
3 Bad oil pressure sensor
4 Blocked Oil Filter
5 Bad oil pump (is there oil pressure?)
Does it flash randomly, or steadily?
nsxtasy Jan 2, 2008 02:41 PM
Re: oil light on (IamPhil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IamPhil &raquo;</TD></TR><TR><TD CLASS="quote">You could still be low on oil, I was taught to check the dip stick when the engine gets to cool since heat expands.</TD></TR></TABLE>
Oil readings should be similar when the car is cold and when it is hot. The oil expands when the engine is hot, but it's also present throughout the engine, whereas when the engine is cold, it has a chance to drain and settle in the oil pan. These two effects offset each other, and the difference between the two readings isn't huge. Try it and see for yourself.
The owner's manual tells you to check the oil level when the car was running and has been shut off for a few minutes. (Like when you stop to fill up with gas.)
95_red_dc Jan 2, 2008 02:41 PM
I did check the oil when it was cold also! It is so weird it should not be the oil pump the motor does not even have 80,000 miles on it. has this happen before to any 1?
mike9571 Jan 2, 2008 02:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_red_dc &raquo;</TD></TR><TR><TD CLASS="quote">I did check the oil when it was cold also! It is so weird it should not be the oil pump the motor does not even have 80,000 miles on it. has this happen before to any 1?</TD></TR></TABLE>
Dont jump to conclusions. Check all these first...as listed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thewrai6th &raquo;</TD></TR><TR><TD CLASS="quote">I would check in this order
1 Lack of oil
Does it flash randomly, or steadily?</TD></TR></TABLE>
95_red_dc Jan 2, 2008 02:45 PM
Re: oil light on (thewrai6th)
It flash steadily when the car is in operating temps and is above idle at idle it is on all the time. The only thing I can thank of doing is to hook up a oil pressure gauge and see what it reads and that will hopefully tell me what i need to know bad oil pump or bad sensor
mike9571 Jan 2, 2008 02:46 PM
When was the last time you changed the oil?
95_red_dc Jan 2, 2008 02:55 PM
Re: oil light on (mike9571)
Its been about 3,000 miles I was about to change it untill this happend
thewrai6th Jan 2, 2008 03:24 PM
Without being there to troubleshoot, i would say change the oil and filter now and see if that helps. Then start looking at your wiring and ECU, because it shouldn't flash steadily.
The oil light blinking like it's your blinker is not normal. If it's just kind of flashing like a loose connection, check your wiring.
DA_9 Jan 2, 2008 04:33 PM
I have the same problem, for me its the oil pressure switch. I have a 91 integra so i dont know if its in the same location but on my car if you look at the back of the engine its i believe below the alternator ull see it its a set of wires with a plug going into the block, move it around see if the oil light goes off or not.
thewrai6th Jan 2, 2008 04:39 PM
Re: oil light on (DA_9)
It's just to the upper-left of the oil filter on a B18C.
clean3two3 Jan 2, 2008 06:07 PM
oil leak my guess my da has a leak thats when the light goes on when its empty.
mike9571 Jan 2, 2008 06:10 PM
Re: (clean3two3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean3two3 &raquo;</TD></TR><TR><TD CLASS="quote">oil leak my guess my da has a leak thats when the light goes on when its empty.</TD></TR></TABLE>
his oil level is fine.
Op, since the light is flickering i will also suggest to check the connection at the sensor.
clean3two3 Jan 2, 2008 07:31 PM
Re: (mike9571)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">
Op, since the light is flickering i will also suggest to check the connection at the sensor.</TD></TR></TABLE>
yea mines flickered too it would go away but ok yea i can believe its like a sensor
95_red_dc Jan 3, 2008 06:40 PM
Well my car is knocking now its gotten worse! It feels like there is no power, really slow. To me it sounds like i'm about ton throw a rod!
mike9571 Jan 3, 2008 07:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_red_dc &raquo;</TD></TR><TR><TD CLASS="quote">Well my car is knocking now its gotten worse! It feels like there is no power, really slow. To me it sounds like i'm about ton throw a rod! </TD></TR></TABLE>
Yikes, sounds like you lost oil pressure and caused some damage. https://honda-tech.com/forums/images...s/emthdown.gif
95_red_dc Jan 3, 2008 07:39 PM
Yep! Its been going down hill since Tuesday I'm really bummed out about it I just bought this car in feb. I don't know what to do now
95_red_dc Jan 6, 2008 06:31 AM
If the car is running and you check the oil it should be all over the stick right? Well mine is not would that mean that the oil pump is out?
Steven. Jan 6, 2008 08:10 AM
On my 94 ac, there is never any oil on the stick i add some and go for a while until my oil light comes on and add some oil and keep on going.. some blue smoke comes out the exhaust if i rev so im guessing its the piston rings
nsxtasy Jan 6, 2008 10:34 AM
Re: oil light on (Steven.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_red_dc &raquo;</TD></TR><TR><TD CLASS="quote">If the car is running and you check the oil it should be all over the stick right? Well mine is not would that mean that the oil pump is out?</TD></TR></TABLE>
It depends on what you mean by "all over the stick". The dipstick has two marks near the end of it. The oil level is shown by the edge of where the oil coats the dipstick, and should be between those two marks. The difference between the two marks is exactly one quart. Most people keep it filled to the top mark (the one further from the end of the dipstick), so that if the car consumes oil, it can consume up to one quart before you notice it, and it will still be okay.
If you are saying that the dipstick is dry, that it doesn't show any oil on it, then the engine doesn't have enough oil. There is a serious risk of damaging your engine by driving it without enough oil. You need to put more oil into it, enough to fill it to the top mark. Then check your oil level regularly (at least every time you fill it with gas) to see how much oil it is consuming.
It's normal for cars with over 100K miles to use some oil, as much as a quart every 1000 miles. If that's how often you need to refill it (hopefully, you're then putting in half a quart every 500 miles, rather than waiting until it's all the way down to the bottom mark) then your best bet is to just keep checking the oil and adding more as needed.
If it's using more than that, then you need to take it to a mechanic or dealer (or DIY but it sounds like you don't have the experience) who can look for leaks, run a leakdown and compression test, test the oil pump, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steven. &raquo;</TD></TR><TR><TD CLASS="quote">On my 94 ac, there is never any oil on the stick i add some and go for a while until my oil light comes on and add some oil and keep on going.. some blue smoke comes out the exhaust if i rev so im guessing its the piston rings</TD></TR></TABLE>
In your case, you have let your engine run dry of oil, as you explained in the other topic. And as explained there, the oil light is not a "low oil level warning light"; it is a low oil pressure warning light, and if you have let your oil level get low enough for it to light, your engine is probably already toast, from you driving it around with no oil in it. Good luck.
g3integragsr Jan 6, 2008 10:49 AM
Your dipstick goes into your oil pan, thats where it gets it's reading of how much oil you have. It doesnt matter if your oil pump is out or not, if you have enough oil in your motor it will show on the dipstick.
the distance from the bottom of the dipstick to the first hole is also exactly a quart........so if you dont see any oil on that dipstick when you pull it out, wipe it off, put it back in all the way and pull out to check it then you are atleast 2 quarts low.
On my B18C1 I notice a huge difference in power and how my motor runs even if it's only a half a quart low. When I accidently let my motor get 2.5 quarts low by not checking it my oil light would start flashing and my car was extremely slow.....as in virtually no power.
I have come to the conclusion that you are not properly checking your oil..........your motor is over 2 quarts low, thats why your light is on and your motor is sluggish
95_red_dc Jan 6, 2008 11:52 AM
I know how to check oil, and I know how to read the dip stick! Some one told me a easy way to test to see if your oil pump is working is to start the car and check the oil if its working properly oil should be all over the dipstick. Well I check it and there rally was not any oil on it. The oil is FULL I checked it when the motor was shut off! My oil light comes on when it starts warming up. It stays on when it is idling and above idle it is steady flash.
thewrai6th Jan 6, 2008 12:07 PM
Test or get someone to test your oil pressure. Use the spot by the oil filter, where the oil pressure sensor is, to tap in.
