odd annoying noises
odd annoying noises
90 teg making 2 noises i cant figure out.
the first noise is a high pitched squeak that comes from the front of the car. its been there since ive had it running for about 2 months. i am almost positive it is not brakes, it seems like its coming from the motor. it only squeaks when moving, and still squeaks when moving with the engine off.
the second is a clicking noise that happens when i turn. like turn and-- click-click.... click-click, if you get my drift.
could the cause of both of these be bad axles? thats what im figuring, i just want to be sure before i change them.
Re: odd annoying noises
They clicking is probably your CV joints. The squeaking is probably something in your suspension/bushings. It could also be your CV joint worn to the point also. Get under it and check out your suspension/bushings.
Might only need one, but replacing both for piece of mind isn't a bad idea. I would also get under it and pry around to check for loose bushings. Since you will be under it replacing axles a bushing kit would make for a nice addition as well.
will do sir, thank you very much
AcCO12D95
02-15-2018 04:59 PM
GagnarTheUnruly
07-26-2011 02:51 PM
