NEED OPINION on gates blue racing...etc.timing belt, water pump
I have been searching what kind should I get for new timing belt, water pump and tensioner on my 94 B18c1 GSR STOCK motor....
Which one of these will be good on my gsr stock motor???? Gates Blue Racing (click on the link) http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT Honda Genuine OEM (click on the link) http://cgi.ebay.com/ebaymotors/ACURA...Q5fAccessories |
Re: NEED OPINION on gates blue racing...etc.timing belt, water pump
get a genuine Honda one. Why do you want a "gates super insane blue ass racing bitch"?
The honda one goes for 100k miles and you can't beat OEM quality. www.bernardiparts.com is a good place to get them. I always also get (all genuine Honda): -water pump -front main seal -cams front seals -tensioner and spring -accesory belts (they're cheap anyway...although I don't mind buying these elsewhere) |
Originally Posted by B serious
(Post 44514624)
The honda one goes for 100k miles and you can't beat OEM quality. www.bernardiparts.com is a good place to get them. I always also get (all genuine Honda): -water pump -front main seal -cams front seals -tensioner and spring -accesory belts (they're cheap anyway...although I don't mind buying these elsewhere) its little cheaper than the website u gave me...... second thing, is it REQUIRE to replace the front main seal and cams front seals during timing belt, water pump, and tensioner same time??? |
Originally Posted by t-del28
(Post 44514688)
did u check the second link???
its little cheaper than the website u gave me...... second thing, is it REQUIRE to replace the front main seal and cams front seals during timing belt, water pump, and tensioner same time??? I cannot recall ever having a single issue with any OEM Honda part I have installed on the car in the 10 years I have owned it, from 89K miles up to the current 297K miles. |
i always opt for the gates belts, people fail to realize that honda parts are made by an OEM manufacturer and rebranded honda, gates belts are gates belts, and their racing belts are excellent quality, i love those kevlar reinforced designs.
Let's remember that the OP is asking about a stock engine.
The Gates Racing timing belt is 2-3 times as much as the OEM Honda timing belt from a place like Carland Acura www.acuraautomotiveparts.org What is the point of using such a belt on a stock engine? Then you consider that the eBay link above with the Gates Racing belt includes what appears to be no-name water pump and tensioner pulley, and suddenly that package doesn't seem so great for $180. For a stock engine, get the OEM parts for $180-$190 and call it a day, until it needs to be done again 90K-100K miles later. |
sorry? gates sells a timing belt component kit for 80 dollars that includes a brand new water pump, oem timing belt, tensioner, and whatever else is needed for the timing job.
GATES Part # TCKWP247 More Information About this Part PowerGrip Premium OE Timing Belt Component Kit W/Water Pump; 3 Components (1 Belt, 1 Tensioner, 0 Idlers, 1 Water Pump) $81.79 |
oh lawds I wouldn't trust that kit for a second, not for 90K-100K miles.
Originally Posted by PatrickGSR94
(Post 44516847)
go to a local parts store and buy the oem parts, i just bought the OEM timing belt for 36 bucks... the timing belt and tensioner kit is 90 bucks...plus 60 for water pump...why you need a racing kit for a stock car?
Originally Posted by Spawne32
(Post 44517010)
you serious right now? lol
(Post 44516485)
The Gates Racing timing belt is 2-3 times as much as the OEM Honda timing belt from a place like Carland Acura www.acuraautomotiveparts.org What is the point of using such a belt on a stock engine? Then you consider that the eBay link above with the Gates Racing belt includes what appears to be no-name water pump and tensioner pulley, and suddenly that package doesn't seem so great for $180. For a stock engine, get the OEM parts for $180-$190 and call it a day, until it needs to be done again 90K-100K miles later. good point, i do understand now, i was thinking more on gettin oem parts for timing belt kits thanks for your opinion |
Originally Posted by mapa1229
(Post 44517200)
oh i see, now thats not bad deal true once its stock motor n get oem parts right.... thanks for ur opinion |
If you count the teeth on the water pump in the first link on the close up pic. You will notice it's a 19t generic pump and not a 22t. You don't want that on a gsr. If you installed what is in the picture it would be a ls timing belt and pump. With those two parts it would work but cause cavitation at higher rpm. It may be a generic picture but I would not buy it because the picture isn't correct.
In the decade I've been doing my own maintenance and repairs on my Integra, the phrase "you get what you pay for" holds true for so many things in so many instances.
since patrick thinks of so full of "misinformation" i pulled part of the US supplier list for honda service parts manufacturers for 2010
ADVICS Manufacturing Ohio, Inc. AGC Automotive Americas Torrance, California AGC Automotive Americas Bradford, Ontario, Canada AGC Automotive Americas Bellefontaine, Ohio Aisin USA Mfg., Inc. American Mitsuba Corporation Asama Coldwater Mfg. ATC Drivetrain Bando USA, Inc. Bucyrus Precision Tech, Inc. Cardington Yutaka Technologies, Inc. Cardington Yutaka Technologies, Inc. CMWA Continental Automotive Custom Engineered Wheels, Inc. DENSO Logistics Tennessee DENSO ASMO Manufacturing Inc. DENSO Manufacturing Athens Tennessee DENSO Manufacturing Canada Inc. DENSO Manufacturing Tennessee Inc. - Electronics Plant DENSO Michigan Automotive Compressor, Inc. Doyle Shamrock Industries DTR Industries, Inc Dyna-Mig Mfg. of Stratford Inc. Elesys North America F&P America Mfg., Inc. F&P Mfg., Inc. FCC (Indiana), Inc. Filtech Inc. Filtech Inc Florida Production Engineering, Inc. Gold Eagle Co. Greenville Technology Inc. Hi-Lex Controls Hitachi Metals America / AAP St. Marys Corp. Hitachi Metals America Ltd. Honda Lock of America Co., Inc. Honeywell Idemitsu Lubricants America Corporation Kaba Ilco Corp Kamco Industries, Inc. Katayama American Co. Inc. Keihin Fuel Systems, Inc. Key Fasteners Corporation Kokoku Rubber Inc. Koyo Corporation Of Usa KTH Parts Industries, Inc. Litens Automotive Partnership M-Tek, Inc. Matsu-Matcor Manufacturing Inc. MBL (USA) Corporation McCord Leakless Sealing Mitsubishi Electric Automotive America, Inc. Musashi Auto Parts Canada Inc. Musashi Auto Parts -Michigan, Inc. NGK Spark Plugs (U.S.A.), Inc. Nifco America Corporation NK Parts Industries, Inc. Remanufactured Parts Ohashi Technica U.S.A. Inc. Omron Automotive Electronics, Inc. Pacific Manufacturing Ohio, Inc. Pioneer Electronics (Usa) Inc. Rollstamp Manufacturing Sensical Inc. Shape Corporation THK America Tigerpoly Manufacturing Inc TOMASCO Indiana LLC Topy America, Inc. UGN Inc. US Yachiyo, Inc. Ventra Plastics - Windsor A Division Of Ventra Group Co. Weastec Inc. Yamada North America Inc. YSK Corporation and thats directly from honda, i dont lie about the shit i post, i just tell it like it is. |
What is your point? I don't dispute that OEM Honda parts come from those manufacturers. Hondas are full of Denso, Nippondenso, NGK, Mitsubishi (alternator), Yamada, Nissin, and many other branded parts.
However the water pumps shown in some of those links above appear to be a "no-name" version, whereas one from Honda will say "Yamada" on it. I don't trust no-name parts like that, for such a critical part to engine operation. Anyway, that's my opinion, you have your opinion. OP can take them for what they're worth. |
ebay is never the best place to buy parts for anything
As for that Gates timing belt kit with water pump, I'm sure the Gates belt is just fine. By itself the belt is around $35 which is the same price if you get it from Honda. But then you have the tensioner pulley and water pump together for basically $50 or less. I simply do not trust those parts being of OEM quality when they're sold that cheaply.
Again, that is my opinion. Take it or leave it. It's not hurting or insulting anyone in any way, shape, form, or fashion. |
help this guy out!
(Post 44514572)
Which one of these will be good on my gsr stock motor???? Gates Blue Racing (click on the link) 94 95 Acura Integra GSR B18C1 Gates Blue Racing Timing Belt Water Pump Tensioner | eBay Honda Genuine OEM (click on the link) ACURA INTEGRA 96 01 GSR WATER PUMP TIMING BELT OEM | eBay |
