B16 DA9
Re: B16 DA9
The distributor will not work with an OBD-1 system... and the fuel injectors aren't right even if you use a resistor box... so use OBD-1 fuel injectors and an OBD-1 distributor. The B16A OBD-1 distributor housing number is TD-44U.
Re: B16 DA9
Your response somewhat confused me. so I CAN Use A OBD1 Distributor OBD1 Fuel injectors on the OBD-0 B16A Head??. Cuz yes the TD44U is what I already have and is what I was using on the OBD1 B16A Head, I Just Got a Different B16A head and turns out to be OBD0. So I was asking if I can Use everything That was on my OBD1 B16A on to the New OBD0 B16A head.
Re: B16 DA9
Mechanically, the only difference between an OBD-0 and an OBD-1 cylinder head casting is the oil spray bars... the OBD-0 bars are cast aluminum and the OBD-1 bars are extruded aluminum and appear very shiny. Externally, all parts are interchangeable and will bolt on. The way you worded your original question suggested that you wanted to install an OBD-0 B16A cylinder head and distributor on an OBD-1 engine... and my response was to inform you that the OBD-0 distributor will NOT work with an OBD-1 ECU. My apologies for any possible confusion.
mynameizstitch
01-26-2010 06:11 AM
