vtec problem
Old 11-30-2010, 09:17 PM
juanq510's Avatar
Default vtec problem
hi i need help asap i have an 01 integra gsr and it hits 1st 2nd and 3rd gear vtec but 4th and 5th dont pass 5000 rpm and i get a check engine light please need help thankz
Old 11-30-2010, 09:30 PM
ServiceAdvisor's Avatar
Default Re: vtec problem
Step 1) pull code(s)
Step 2) resolve corresponding problem(s)
Step 3) profit
Old 11-30-2010, 09:37 PM
juanq510's Avatar
my boy pulled a code nd it was a vtec problem but couldnt figure out wat is causing it?
Old 11-30-2010, 09:47 PM
Well, lets start off by you giving us all the details you can.
What mods are done to the car?
When did it start doing this?
What codes did you pull? Need to know them all if you want us to be able to help.
Old 11-30-2010, 09:52 PM
danielblushtein's Avatar
https://honda-tech.com/forums/acura-integra-6/ecu-abs-codes-here-978933/
check ^^ out. See what code you got.
Old 12-01-2010, 10:00 AM
juanq510's Avatar
Is the code 22 vtec pressure valve
Old 12-01-2010, 10:35 AM
Code 22 is most likely caused by low oil pressure which could be from a few different things. Lack of oil, bad oil pump or clogged strainer/pickup, screen on VTEC solenoid clogged. Also damage to the wiring could cause it to not engage, though from you description of it only happening in 4/5th.
Start off by verifying you have the proper amount of oil.
Next remove the VTEC solenoid and clean it
Remove bolts, spray liberally with brake kleen or similar product. Replace gasket, I think its around $5 from Honda.
Next I would verify continuity at the harness.
http://www.preludeonline.com/f28/hel...h-pics-219712/
This is again for a Prelude but similar
If all this checks out then replace your VTEC solenoid with a new one or a working unit barrowed from a friend. Lastly, I would suspect oil pump or pickup tube problems. In which case, you would need to remove the oil pan and inspect for damage/problems.
Hope this helps - SA
Last edited by ServiceAdvisor; 12-01-2010 at 10:37 AM. Reason: link was blocked :/
Old 12-01-2010, 04:52 PM
juanq510's Avatar
i recently did a oil change and is not leaking so i dont think is that? but is weird how 4th and 5th dont pass 5000 rpm at all and wen i try passing 5000 rpm in 4th gear it wont let me it will **** back and after that happens in any gear u cant hit pass 5000 rpm? but then i turn off the viechle and then 1st 2nd and 3rd start to work again? so its weird?
Old 12-01-2010, 08:49 PM
The CEL is triggering your ECU to go into "Limp mode". This will restrict the vehicle from accelerating past 5k rpms and possibly damaging itself. Have you removed the VTEC Solenoid yet to verify its clean and not obstructed? Checked the wiring for any damage/breaks?
Old 12-02-2010, 01:31 AM
Technical Hero
HondaPartsHero's Avatar
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
wrx'n you
02-03-2007 01:07 AM
DohctorVtec
01-16-2007 05:43 AM
over_
12-02-2006 03:55 PM
Hondasaurs
05-09-2003 08:51 PM
boost killz
09-07-2001 07:01 PM
Quick Reply: vtec problem
