Napa gear oil?
I just bought a few bottles of this oil to run in my gsr tranny, it's 80w 90 gear oil, here is a link to the product http://napaonline.com/MasterPa...otive has anyone used this product and do you think its safe to try? It says it's made for manual transmissions w/ or without lsd in passenger vehicles so It seems like a good idea, I just need some opinions or reviews.
Re: Napa gear oil? (TylerC)
If your tranny is working fine.. then use OEM fluid https://honda-tech.com/forums/images/smilies/emthup.gif
If grind a little probably use penzoil PN: 3501 syncromesh |
Re: Napa gear oil? (DC_RaceR)
i ended up takin it back, I was to scared to use it, sticking with honda mtf
that's REALLY thick, honda mtf is only 10w 30 weight, i believe...
i wouldnt expletive with that. |
Re: Napa gear oil? (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 »</TD></TR><TR><TD CLASS="quote">that's REALLY thick, honda mtf is only 10w 30 weight, i believe...
i wouldnt expletive with that.</TD></TR></TABLE> Gear oil and motor oil are not rated on the same viscosity scale, so 80w-90 gear oil is not nearly as "thick" as an 80w-90 motor oil would be. However, I do agree that sticking with Honda MTF or GM/Pennzoil Synchromesh is the best idea. |
Re: Napa gear oil? (Padawan)
good to know. thanks.
