My hood won't open. i need help
when i tried to open my hood, the hood release stays out and the hood don't pop up.
Re: My hood won't open. i need help (tegracer19)
Spray some WD40 in there, had the same problem with mine. Let it soak for a few mins.
Re: My hood won't open. i need help (Arsenal)
where do i spray it?
Your cable could be broken under the hood. When you do get it open again look down at the release latch and make sure its not worn badly or broken.
the cable on my old crx was stretched, so what i had to do was have someone push down on the hood and i would have to pop it at the same time, try that once.
Re: (ljoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ljoe »</TD></TR><TR><TD CLASS="quote">the cable on my old crx was stretched, so what i had to do was have someone push down on the hood and i would have to pop it at the same time, try that once.</TD></TR></TABLE>
^^^^ try that. Lube the hood latch after you get it open. |
