high rpm's on hwy is normal?
Is normal 3700-3800 rpms at 80mph on auto what it is on manual if anybody knows, i read that using the YS1gsr manual on this engine is basically the same but the LS manual is a bit lower on rpms, can anybody confirm by experience
thanks for your help
Re: high rpm's on hwy is normal?
That seems about right. Be glad its not a ITR Trans. 70 on the highway im at 4k. 70 with my old LS i think was about 3400 is normal.
damn short ratio trannys =(
ls 4k @ ~90
gsr 4k @ ~80
itr 4k @ ~70
if you want some mad free way mpg then you should find a long *** gear and swap out your 5th
but i'd imagine climbing hills on 5th w/ a long 5th is going to suck... unless you build mad speed before hand
ls 4k @ ~90
gsr 4k @ ~80
itr 4k @ ~70
Thats why I have 2 transmission now. One for DD until i finish rebuilding my $600 perfect conditino 98 Legacy GT. LS Great gas milage especially on the highway Im seeing about 31mpg. And my ITR with Factory LSD carbon moly syncro rings. Which i am currently deciding if i want to toss in a 5.01 FGD.
FeelTheBass
14
03-28-2014 07:44 AM
Acura_I-RS
12-11-2002 04:58 PM
