low idle
i have a low idle all the time and i just wanted to know some ideas what can cause this? so if any input let me know please.
Re: low idle (LSDA9Nick)
Sounds like a fuel problem. Fuel Filter, injectors, Fuel Pressure Regulator, Fuel Pump. Check them all. Id start with the filter.
What does it idle at? It doesn't die or sputter does it?
Re: low idle (mrdeadman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman »</TD></TR><TR><TD CLASS="quote">What does it idle at? It doesn't die or sputter does it?</TD></TR></TABLE>
How is drivability?? If it drives fine, but idles badly, that can be adjusted on the throttle body |
Re: low idle (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">
How is drivability?? If it drives fine, but idles badly, that can be adjusted on the throttle body</TD></TR></TABLE> I would check this first, before I started replacing fuel system parts. |
idles at about 600, but doesnt die it feels like it wants to but doesnt |
How is drivability?? If it drives fine, but idles badly, that can be adjusted on the throttle body</TD></TR></TABLE> drives good idles low |
