Changing studs??
Old 01-16-2010, 03:14 PM
airikkCRX's Avatar
Default Changing studs??
What is the best way to change the studs in the front of my integra some people say you have to remove the hub and I hear that you don't thanks for any advise
Old 01-16-2010, 03:32 PM
TheAsian's Avatar
Default Re: Changing studs??
Yes you need to remove the steering knuckle and press the hub out. You wont have clearance any other way
Old 01-16-2010, 03:56 PM
ZOOYOST's Avatar
remove wheel
remove caliber
remove rotor
remove axle nut
insert slap hammer (pound away)
vise put hub tighten down
tighten lug loosely to stud smack it loose.
remove lug once loose and slip stud out. (so stud doesn't fly)
fyi put the stud in the freezer
air hammer
once done
slap hammer back on the studs
pound away again
put axle bolt back on to drawl in hub to wheel bearing.
once tight rotor and calibur and wheel.
*aftermarket stud* might have to grind down the stud so i doesn't rub.
Old 01-16-2010, 04:00 PM
TheAsian's Avatar
how did you find clearance?
Old 01-16-2010, 04:05 PM
ZOOYOST's Avatar
mildly slap it back on twist the hub around if it touches then grind it. the skunk2 extended on eg and dc you must grind the stud towards the hub. plus grease them
Old 01-16-2010, 04:31 PM
TheAsian's Avatar
Ill have to use that trick. thanks make life in the shop easier
ewoo
02-24-2009 04:23 PM
simonEp3
09-03-2008 04:49 PM
NeWsCr
12-13-2006 06:43 AM
JJ's civic
09-29-2006 05:01 PM
typeeg
07-20-2004 05:21 PM
Quick Reply: Changing studs??
