Leaking oil from shift linkage hole to tranny.
The hole with the 12MM bolt thats holds the shift linkage to the tranny. not the one with the pin. But anyways, its leaking and i ahve no idea what to think.. is my tranny garbage or is this some kind of problem that can be fixed?
Re: Leaking oil from shift linkage hole to tranny.
You're talking about the rigid torque rod that doesn't move when shifting, that has the donut-shaped bushing in it? Sounds like your trannt case may be broken because that hole should not be open to the inside of the case at all.
Make sure it's actually coming from that hole and not somewhere else near/above it.
Yeah, The hole has the donut shaped bushing that doens't move.nope its def. coming out of that hole, when i had the motor up off the grond witht he engine hoist, and i leaned the motor a bit, the oil starts pouring out. Because i figured since that hole don'st have to do anything with the tranny, my tranny might be garbage huh?
Yeah thast what i was assuming too. But can i still drive it? or do you suggest a new tranny jsut to be safe? I don't wanan drive it and then my tranny falls apart on me.
I dunno... do you notice it leaking or dripping all the time? You should probably replace the tranny case or at least try to seal it up from the inside somehow (take apart tranny case). In the meantime, you could probably just throw some thread sealant on the bolt, like maybe some teflon tape, and see if that keeps it from leaking.
so its still driveable correct? if i just put some thread sealant and put the bolt back in, it should be ok?
bump. i'm having the same issue and my trans will only shift into 1st and 2nd but 3,4,5,R will not go in. would that be an issue for me to not get into gear?
hmm, i dunno if that would cause you not to shift into gears, unless you're loosing too much oil/fluid. I assumed that once that a bolt is in that hole, there shouldn't be anymore leaks.
i got the same issues with that hole too i put honda bond in it too and it stoped car seem to shifte fine
yeah once i put the bolt in then there are no more leaks. but i think it's something internal in the transmission for it to not shift into gear. thanks for the help though guys.
hm, i guess i should try that first. and if all goes bad, i'll jsut get antoher LS tranny. like 250 around here.
where to buy honda bond? at the dealership? lol stupid question. but i will let you guys know of the results after i put in my motor+tranny,
Shaun
12
10-18-2006 07:47 PM
