JDM p72 okay for GSR?
i have a GS-R...right now i have a stock USDM p72 ecu OBD2...will it be okay/better to switch to JDM p72 OBD1? will i need a 00-01 converting harness wiring like the skunk2?
Re: JDM p72 okay for GSR? (KriLYu)
you will need the conversion harness, but its not worth it to switch to a jdm p72. From what i've heard, the jdm p72 has a speed limiter, and isnt good for chipping....i think it would be a waste of money, but thats just MHO
Re: JDM p72 okay for GSR? (iH8RICERZ)
well, i got an OBD2 and i want to switch to OBD1...so, i should just get the USDM ecu instead of an JDM?
i would get a usdm p72 obd1...but what are you plans for motor modifications? I have a friend selling a stock p72 obd1 and a mugen chipped p72 obd1...and I also sell chipped p28's...depending on your plans or your motor mods right now, i can recommend something for you.
for now i just want a stock p72 obd1...i plan on puttin on comptech I/H/E for now and get a VAFC...
maybe in the future put some skunk2 cams, IM...i heard hondata is the best to chip the ecu? wouldn't a JDM p72 be better than a USDM p72? |
yes..hondata is the best way to go........Theres not much difference between the jdm and the usdm p72. But i would just stick w/ a usdm one. If you do plan on getting the skunk2 cams and a new IM, then i do recommend selling the p72, and look into trading or buying a chipped p28, or just look directly into hondata
u telling me to stick with my stock ecu that is OBD2?
I've dyno'd back to back with both USDM and JDM P72 OBD-I ECU's. Same fuel cut rpm and seemingly the same fuel mapping. No changes in power or redline.
Re: JDM p72 okay for GSR? (IN VTEC)
the JDM and the USDM p72 OBD1 is the bacially the same inside the computer? and JDM is more smaller, right? how about the wiring harness? will that be the same? cuz i know i will be needing a 00-01 obd2-obd1 converting harness..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KriLYu »</TD></TR><TR><TD CLASS="quote">the JDM and the USDM p72 OBD1 is the bacially the same inside the computer? and JDM is more smaller, right? how about the wiring harness? will that be the same? cuz i know i will be needing a 00-01 obd2-obd1 converting harness..</TD></TR></TABLE>
Yes, if you want to convert to obd1, the obd2B-1 conversion harness is needed. JDM ecu's are usually smaller than the usdm ecu's. And yes they are basically the same. |
if i upgrade to a skunk2 IM, what would hondata recommend? p72 or p28?
