JDM B18c Type R swap Questions
Ok well heres the deal guys i baught a JDM B18c Type R im about to do the swap all myself ..i already took off the RHD harmess ..the motor is OBD2 so is my car ..im planning on using my gsr OBD2 harness..i already put it on but came across some problems the clip to alternator on the gsr harness is too big for i was thinking of cutting it & using the one off the ITR harness & rewiring ? Also theres some few things i was looking at & couldnt figure out what they went to..other then that i have it nailed ..ill post some pics & let you guys know what im talking about.
Im not sure where this little hose go to any ideas?
Also this one ive looked already in my bay & couldnt find where this goes to
Found this but have no idea where it can go to ..its on the driverside of engine bay
This is what i found on the passenger side bay that can maybe match up to either pic 1 or pic 2
& last...i saw this on the driver side by rack & pinion could it go to something ?
Thanks for some help & tips!
Re: JDM B18c Type R swap Questions
Pretty sure pic one goes to a solenoid that is mounted on the firewall, and pic 2 is for the evap system and goes somewhere to the charcoal canister. Not too sure about the plug and other pics.
As to cutting of and splicing in the type-r alternator plug, if it has the same wires then it will work.
Ok sweet thank ! & yes all are same wires it was a success! also extended IACV sensor it was to short on gsr but i jst looked in my bay the is no charcoal canister it has been removed.
Ok cool it wont throw any codes by doing that or can you relocate that if not it cool i can get nipple on it..also where is solenoid that is mounted on the firewall i cant find it
I agree.. did the same with a 96 GSR. Used a newer USDM GSR wiring harness for the engine, extended the IACV, cleaned up the extras no longer used (IAB, CKF, etc) and it works wonderfully.
I capped the small vacuum fitting in the top pic. I think DA9 is right - it's all related to the JDM version of EVAP. That extra steel line that comes from under the car is a part of that (vents fuel tank through a pressure regulator to the EVAP purge canister).
ok so in the first pic all you did was take line out & put a cap? & worked?
well everything forsure shld bolt right up ..but confused on my engine bay theres the vtec wire i knw that but theres also the tranny sensor & sensor that goes to head ..which those two are on the harness..idk which i shld connect to..the ones coming out of firewall or two that are on harness minus the vtec wire . This is what im tlking about
That's right under the VTEC solenoid right? That should be the ECT or the temp sending unit. The one we are talking about plugging is the second picture. And I don't know about the DC's but on the DA's the solenoids I was talking about is mounted on the fire wall right above the intake manifold. One is evap, one is fuel pressure related, and other one connected is MAP related. Picture #1 should go to the MAP related solenoid.
Yes its located under vtec solenoid ..my harness has the clip for it also has the clip for sensor thats in front of tranny but i also have those two & vtec wire coming from my engine bay ..idk which of those to use? & so like you stated i can put a nipple where the line to the charcoal canister goes ? & how mark@silbernage said he jst capped where the line goes in pic 1 where little hose is too?
You can cap the line in the first pic, but I would run that to the MAP solenoid thing when you find it. Maybe your car is different though, I have a DA so I dunno. I believe the plug you are talking about in front of the tranny is either to the fan or o2 sensor. Take a picture? If this is a JDM motor then there should only be a gray plug at the VTEC solenoid. It will be missing the green one (oil pressure switch). That should help you figure out your vtec wiring situation. There are write ups on bypassing the switch.
Yeah my car doesnt have MAP solenoid so ill prob jst cap it & yes my motor is a JDM b18c ITR motor doesnt have (oil pressure switch)
If you're using a USDM ECM, you'll need to look up the CKF bypass (you don't have one) and a VTEC switch bypass (don't have one of those either!).
VTEC Switch: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/vtec-oil-pressure-switch-bypass-really-simple-1693528/
CKF Bypass: http://www.ff-squad.com/technet/ckftrick.htm, http://ff-squad.com/wp/?p=309
On that electrical connector, what are the color codes? Also, if you can get a picture looking into the connector, or tell us how many pins it has.
I'll be using jdm ecu jdm motors don't come with oil pressure switch so I won't be needing a bypass. & connector has two pins
Ok well I have clip that connects to on harness obviously but also have it coming from my engine in my fire wall along with vtec wire witch will hook up to vtec solenoid but also have the clip goes to sensor in front of tranny not the o2 sensor..
OKAY heres the scoop i recently pulled out my 96 ls b18b1 engine due to low compression burning oil and finnaly a rod knock . I had been saving up money for an 96 spec JDM HONDA INTEGRA TYPE R engine known as the b18CR http://www.flickr.com/photos/90679746@N02/8236219264/http://www.flickr.com/photos/90679746@N02/8236219264/ by http://www.flickr.com/people/90679746@N02/, on Flickr
After awaiting for the arival of my engine i decided to start pulling mine out
starting by jacking up the car removing hoses radiator harness axels and imput shaft and castle nuts to lower control arms
http://www.flickr.com/photos/90679746@N02/8235153305/http://www.flickr.com/photos/90679746@N02/8235153305/ by http://www.flickr.com/people/90679746@N02/, on Flickr
next removed all four motor mounts and lower transmission mounts and shes almost ready to come out
and finally with slight nudging and swaying I got her out.
http://www.flickr.com/photos/90679746@N02/8236217426/http://www.flickr.com/photos/90679746@N02/8236217426/ by http://www.flickr.com/people/90679746@N02/, on Flickr
Now finally the arivial of my new love I had her imported from japan thru jdm engine corporations she came fully packaged and nothing was damaged during shipment
http://www.flickr.com/photos/90679746@N02/8235150073/http://www.flickr.com/photos/90679746@N02/8235150073/ by http://www.flickr.com/people/90679746@N02/, on Flickr
next before putting her in her place i had some modifications to do.
I utilized the oil pump cover on the ls and put the type r internals into the ls oil pump cover soo i didnt have to bypass the cfk sensor at this time i removed the oil pan and windage tray to check the crank shaft for authenticity .http://www.flickr.com/photos/90679746@N02/8235151621/http://www.flickr.com/photos/90679746@N02/8235151621/ by http://www.flickr.com/people/90679746@N02/, on Flickr
After that i drilled a whole in my Intake Manifold to intall a boss for my Map sensor that ran to my evap canister soo i can have my swap legal and barred .
I swapped my ls harness onto my ITR everything plugged up fine
http://www.flickr.com/photos/90679746@N02/8235152211/http://www.flickr.com/photos/90679746@N02/8235152211/ by http://www.flickr.com/people/90679746@N02/, on Flickr
Look at that empty engine bay guess what ? its time to put the big brother back in his place
the siblings together gettin some quality time . http://www.flickr.com/photos/90679746@N02/8236214078/http://www.flickr.com/photos/90679746@N02/8236214078/ by http://www.flickr.com/people/90679746@N02/, on Flickr
with lots of coffee and motivation it was time to drop the big boy into the dc
http://www.flickr.com/photos/90679746@N02/8236215896/http://www.flickr.com/photos/90679746@N02/8236215896/ by http://www.flickr.com/people/90679746@N02/, on Flickr
l
fit in like a glove and tightened down all the mounts http://www.flickr.com/photos/90679746@N02/8235150645/http://www.flickr.com/photos/90679746@N02/8235150645/ by http://www.flickr.com/people/90679746@N02/, on Flickr
axels contol arm and suspenion harness hoses radiator and everything all hooked back up http://www.flickr.com/photos/90679746@N02/8236213326/http://www.flickr.com/photos/90679746@N02/8236213326/ by http://www.flickr.com/people/90679746@N02/, on Flickr
and after replacing a starter with a brand new one lower ball joints and gaskets replaced she is finally back on her wheels and started up the first try http://www.flickr.com/photos/90679746@N02/8236219784/http://www.flickr.com/photos/90679746@N02/8236219784/ by http://www.flickr.com/people/90679746@N02/, on Flickr
List of Modifications
Apexi GT 4-2-1 Headers
Yonaka 2.5" catback exhaust
MagnaFlow High Flow Catalytic Converter
Skunk 2 Pro series Camber Kit
SkunK 2 Coilovers/Shocks
JVT Racing 6 Core Aluminum Radiator
DC SPORTs CAI 6006 cold air intake system
Ebay slim fans
Megan Racing Front and Rear Strut Bars First Gen
Hope this write up made it a lil easier
l
Ebay slim fans
commotion
25
06-18-2009 08:29 AM
