Need some help
Re: Need some help (Bradle3)
You will have to get the hub pressed out and the stud knocked out. That **** cost way to much money, if i were you id just buy a used hub assembly from a junk yard or HT market place. It will come with rotor, brack bads and even a brake caliper.
take all of the shields off around it and hit it out with a hammer then put a new wheel stud in, it is kind of tricky the first time but im sure you can firuge it out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_dc_fan »</TD></TR><TR><TD CLASS="quote">hit it out with a hammer and pull the new one through by tightening with your rim</TD></TR></TABLE>
its not only the sheild thats in the way, you will have to get the hub pressed out, trust me i have done it before.
