Jackson Racing -vs- Vortech
I've got a 2000 GSR and im gonna go supercharged soon, I've done plenty of research and I STILL cant decide between Roots style and Centrifugal, Suggestions??
Re: Jackson Racing -vs- Vortech (XITruthIX)
Around town power: Roots
Best drag times: Vortech If you decide centrifugal just get a turbo instead. |
If I remember correctly, the jrsc gsr did a faster quartermile time than the vortech.
Re: Jackson Racing -vs- Vortech (qtiger)
i did research on this awhile ago. i forgot what the reason that came up are, but i remember something like the vortech is really bad compared to the JRSC. Im not sure if its for imports vs domestic, or it couldve been its bad for a LS which i have. I might be posting some info that has no use to you, sorry if this doesnt help at all.
Definetly go w/the jrsc. This will give you way more power w/out really changing your stock internals. It runs fine w/new plugs and wires(upgraded of course). Basically, it's cheaper, and it's not so hard on your engine. I've been researching this for the last 3 months or so and Turbos can definetly give you more power than a supercharger but it will also cost you way more, and you will have to fine tune it to put up better numbers than the jrsc.
I am saleing my JRSC now, had it for a while and ran 10 psi, it is fast, vortech sucks, either go w/ Jackson or turbo it, I am going turbo becaus I want more power, but everyday driving JR is good, I have a Delsol w/ GSR and JRSC @ 10psi and was running w/ the new lightings, and smoked GT's all day
Re: Jackson Racing -vs- Vortech (Havokmkr)
Vortech = Supercharger with turbo style lag... either go with the JRSC or go turbo. If you look at any dyno plot from the vortec, you'll see that it has great peak numbers, but no low and not very significant midrange... IMO, they just aren't right for small displacement engines.
Re: Jackson Racing -vs- Vortech (C_tech97GSR)
Go with jrsc. My buddys LS has a vortech kit on, no low end its all peak power. Its just a shaft driven turbocharger.
Re: Jackson Racing -vs- Vortech (AnNiMosSiTY)
I am also bout to get a JRSC, but what cams work good wit it? regular performance cams or Turbo cams?
Re: Jackson Racing -vs- Vortech (garados)
JRSC is better.
but a turbo kit is the best. |
Re: Jackson Racing -vs- Vortech (G3gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G3gsr »</TD></TR><TR><TD CLASS="quote">I am also bout to get a JRSC, but what cams work good wit it? regular performance cams or Turbo cams?</TD></TR></TABLE>
stock cams. |
Jackson.
Re: Jackson Racing -vs- Vortech (Jackson4Door)
Jackson. The vortech doesnt make peak boost until redline. I have run 12's with my JRSC. https://honda-tech.com/forums/images/smilies/emthup.gif
gmoore |
Re: Jackson Racing -vs- Vortech (tegunderpressure)
I'd go with Jackson Racing, it is known to be more reliable than others like Vortech.
Why not go turbo though? JP |
Re: Jackson Racing -vs- Vortech (HondaJon)
Kinda on topic my friends ls with the vortech kit just took a shit on him yesertday. Idler bearing bracket snapped off from getting to hot. So he has to take all the shit off and send it to vortech theyre gonna fix it or givem a brand new one they said.
Wat times do the Jrsc usually put out in a GSR? If i get one im looking towards to be getting low 13s to high 12s wit slicks and off header!
I have a GSR in my Delsol, when I had my JRSC on @ 10 psi I was runnin 12.8 in the 1/4
Re: Jackson Racing -vs- Vortech (93solsigsr)
I am runnin 17's w/ street tires, but I allso have every possible bolt on
How much you sellin the JRSC kit?
Re: Jackson Racing -vs- Vortech (Skunk2nR)
it's on ebay check it out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93solsigsr »</TD></TR><TR><TD CLASS="quote">I have a GSR in my Delsol, when I had my JRSC on @ 10 psi I was runnin 12.8 in the 1/4</TD></TR></TABLE>
How heavy is the Delsol and wat other mods did u had? |
hm... Then I think I'll just go with a T3/T4 hybrid....
Adam just go turbo. But it wouldn't really matter because I still own you. haha. seriously just go turbo. iIs better in the long run
Re: Jackson Racing -vs- Vortech (B18C5crx)
i had a friend who got the JRSC and he liked it alot. i was gunna get one myself but the blower on the LS is smaller than it is on the gsr. JRSC https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
