integra seems to lag/lack power at lower rpms
untill i hit about 4k the car seems like its not getting the air fuel mixture it needs, i really need to pick my self up a ratio gauge soo i can fine tune my FPR but im cheap and only bought fpr gauge, i just slopped a new O2 sensor in there , i did also have a leak in the thermostat housing which i think may have effected it cause the b20 has the ECT sensor right in the thermostat housing and could have had a air bubble and read engine temp wrong screwing with the mixture... o well gotta wait 24 hours for sealant to cure till than i hope either of them was the fix.
Re: (mtber)
i was throwing a o2 sensor code , but now im not but it seems to be loping at idle really slow no5t like a vaccum leak drops to about 750+ than rises to about 1500 in about ten seconds a cycle
Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">A autometer a/f guage won't tell you **** :-)
You need whats called a wideband oxygen sensor to really tell whats going on. </TD></TR></TABLE>
took the words right out of my mouth, spend liek 300 and pick up a wideband
btw remember you drive a honda. dont expect gobs of torque
Re: (Lmaonade)
but a b20 still has torque, i mean it LAGS like this is not by any means normal almost like the throttle cable isnt being pulled till i give it full throttle
Re: (R6E6I6D)
I like the fact that you mentioned vacuum leak. check for them. it's possible you have one since you were playing with your FPR.
has a timing belt been done recently? does it idle roughly aside from the surging idle? check your base timing.
Re: (R6E6I6D)
could TPS be the cause of these problems by any chance>? cause when disconnected it lags worse but in the same way untill about 4 grand she starts picking up
Re: integra seems to lag/lack power at lower rpms (R6E6I6D)
could this b caused by map sensor going bad>? my buddys accord did the same thing b4 and the map sensorwas bad
Found vaccum leak in the top part of the aem fpr... when I went to change diaphram which i figured shitted out turned out it was the stupid metal connector the vaccum hose connects to soooo i dripped a bit of gasket maker **** on the out side of it and with a vaccum pump fromautozone pumped it to about 10lbs of vac and it sucked the gasket stuff in and i let it dry now it holds up to 25 In/hg lbs whatever
