Integra ls build
Okay so I've been reading the forms here for years but am just now joining. So my goal is 500whp b18b1. Already have arias 8.9:1 nitrous/turbo pistons, Skunk2 alpha rods, Arp head studs, cometic headgasket .061 in. I believe. clevite bearings, walboro 255. p75 with s300. Have ls head with port job and dual springs and retainers on the way. Planning on going with the CNC werks CSS. Gt35r 1000cc injectors not sure on brand yet deff want disc style tho. I guess you could say it's a pretty common build. Any thoughts or suggestions would be much appreciated 😁
Re: Integra ls build
500HP is do-able but it will need to change up on some of the stuff you have....like the fuel pump.
You will also need: - upgraded clutch - quality turbo manifold - efficient FMIC - good suspension setup - quality fuel pressure regulator (nothing mounted on the fuel rail....those are GARBAGE) - good engine mounts - GOOD TUNE |
Sounds like fun. What fuel will you be using?
Was planning on pump gas with possibly a sno boost system idk yet e85 sounds fun. And I was also planning on an eBay equal length ramhorn. I work at a welding shop so adding braces isn't an issue. Stronger clutch is a given also need to find an lsd. There's a good tuner about 45 mins away who specializes in important so it will be going there for the tune.
And I thought a 255 maxed out around 600hp?
Do yourself a huge favor and upgrade your suspension and brakes BEFORE boosting your car. Also you’ll want to invest in some good tires. |
Originally Posted by Alex Safford
(Post 51751054)
(Post 51751053)
E85 makes it more plausible, but then you definitely need a better pump and bigger injectors. Go with a Walbro 450 and FIC 1650cc injectors. |
Originally Posted by NVturbo
(Post 51751103)
It may be but it wouldn't hurt to have a larger pump.
Originally Posted by 2x0
(Post 51751126)
Pump gas will make it more difficult to reach your goal, will need a very good tune.
Here is what I had in mind.
https://www.snowperformance.net/Stage-2-Boost-Cooler-Water-Methanol-Injection-Kit-p/sno-20010.htm |
Also already have nice intercooler my brother was running on his Supra mk3. Just need piping,bov,and wastegate.
(Post 51751280)
https://cimg5.ibsrv.net/gimg/honda-t...965c994b09.jpg https://cimg7.ibsrv.net/gimg/honda-t...c2a63bfc11.jpg |
Will be running external wg not what's on turbo now lol
lol Do you work on your car while barefoot? |
Originally Posted by Free Man
(Post 51752264)
(Post 51752290)
Sometimes lol the parts were in my house though that's why I'm bare foot
Be careful though, I’m sure you’d rather have some socks and leather covering those toes when you drop a short block on them |
(Post 51752657)
Damn thats 😎. Be careful though, I’m sure you’d rather have some socks and leather covering those toes when you drop a short block on them |
https://cimg9.ibsrv.net/gimg/honda-t...745b3b5f56.jpg
https://cimg8.ibsrv.net/gimg/honda-t...8beb469d13.jpg https://cimg6.ibsrv.net/gimg/honda-t...dd2d7c329.jpeg https://cimg8.ibsrv.net/gimg/honda-t...ea8938598.jpeg https://cimg1.ibsrv.net/gimg/honda-t...ecd69b212.jpeg Some pics I had of the car. Motor is about to come out just need to pull Axel's and unbolt mounts then prep for cnc werks |
I see you’re running a Lil breather filter on your pcv valve. I was wanting to do this on my b18a1 but I got some confusing info. Any benefits to it you can speak of from experience? |
What type of strut bar? |
As far as I know the little filters are just for appearance lol. And the strut bar I'm not sure the car came with it.
(Post 51755339)
