Integra Gsr Wobbles/shakes under acceleration
Old 08-21-2009, 05:03 PM
Christofurr's Avatar
Default Integra Gsr Wobbles/shakes under acceleration
My Integra still shakes when I accelerate.
I need some help.
I am going to lift the car tomorrow and try to fix this problem.
If you can, please leave some things that I can do to stop this ****.
Thanks
I do not think its my wheels.
Tried rotating and checked psi.
Almost positive its not my axles too.
Old 08-21-2009, 05:10 PM
DKYamada's Avatar
Default Re: Integra Gsr Wobbles/shakes under acceleration
even tho you say its not, i think its your axles.. sounds like a boot ripped.
Old 08-21-2009, 05:26 PM
patdow1's Avatar
^ ^^Agreed
Check tires for cupping as well
i checked the boots, and they are fine
Old 08-21-2009, 08:39 PM
anyone?
Old 08-21-2009, 10:33 PM
darkstarsinner's Avatar
Have you gotten an alignment lately? When is the last time you had your wheels balanced. My Integra did this when for about a month. I finaly got fed up and had my balance checked and my front right was way off. After they re-balnced it, the shaking quit.
Old 08-22-2009, 05:15 AM
im going to try some balanced wheels today
any other suggestions
Old 08-22-2009, 05:18 AM
B16CRXT's Avatar
the axle can still be bad if the boot isnt torn. Is it OEM?
Old 08-22-2009, 07:01 AM
ya oem
Old 08-22-2009, 07:21 AM
GSaura's Avatar
Wobbling and shaking under acceleration is a really good story for a messed up axle
Old 08-22-2009, 07:55 AM
any other things to check for
there can be more things to check
Old 08-22-2009, 09:05 AM
Vegas13's Avatar
Is it the stock motor? my motor was swapped and the guy put it in thru the bottom, and never tightened any supports, mounts, anything, and for the first month i had it i had knocking sounds and shaking, then lifted it and saw all of the mount bolts loose and contorl arm bolts. So check all of that stuff
srok1
09-04-2009 07:21 PM
japinoyian09
04-23-2009 01:59 AM
SiShane
08-23-2008 07:41 AM
Random.Hero
10-03-2007 09:55 AM
John.
07-28-2006 10:56 AM
Quick Reply: Integra Gsr Wobbles/shakes under acceleration
