integra gsr randomly dies
I have a 97 gsr with 156xxx miles. Recently my car has been dieing while making turns or coming to a stop. The car seems to struggle to stay running sometimes when I come to a complete stop. My cel is on and flashing and so is my maintance light lol and is throwing misfire codes and random misfire and the p1399 code. I am also guessing that my car has a bent valve because after I adjusted the valves after about 300 miles the misfire is back. I was wondering what is causing my car to die when making turns
Re: integra gsr randomly dies
Does it die when you step on the gas while turning? I would fix your misfire codes before doing anything else. Also how does the car idle?
You would have to take care of the misfire codes and go from there. Be sure to thoroughly check your plugs(check gaps also) and wires.
the car idles fine most of the times it just seems like its going to die when I come to a stop and if it doesnt die it will idle normally again
The car is bone stock correct? Have you tried cleaning your IACV?
the car only has 4-1 headers but they are smashed lol and I will clean the iacv today
The flashing cel is informing you that your cat is being damaged by the misfires.
