Integra doesn't always start
#26
Re: Integra doesn't always start
Mine does this to. Main Realay is most likely the cause because i have noticed wen it does this if i bang the dash where the main relay is bolted to it fires right up..
#27
i was having the same prob but wasnt throwing any codes. after messing with a couple things i checked the voltage on my tps and it was off a bit. i readjusted it and i have not had a prob with my car starting since(almost 2 months). give that a try
#29
#31
#32
Well it turns out it wasn't the distributor cap.
It sounds like it could be the ECT.
Would high RPMs even after car is warmed up be a sign of a bad ECT?
Sometimes the RPM is high sometimes not.
When it is high, it stays at roughly 2200 RPMs and about 750-900 RPMs when low.
It doesn't Rev high all the time though.
I get horrible gas mileage, it somewhat does smell like rich gas at starts.
#33
I have a 95 teg with similar problems but it dies sometimes after driving it and the idle is always at 1k rpm and has a lagged start in cold starts, but recently it doesn't start at all, my brother is a mechanic but lives across country and says it might be the fuel pump can anyone give feedback on this
#34
the usual suspects:
Honda Acura Essential Electrical Repair Website. Troubleshooting Main Relay, Coil, Igniter, etc.
ignition coil is my #1 no start villain.
always carry a spare.
main relay/icm/ fuel pump
will also likely dump on you at some point.
MulletManRockStar
11
09-19-2004 02:44 AM
