instrument cluster not working
so I was on my way to work today an everything on my cluster was working
I got off an the only lights coming on are the battery high beam an hazards?
turn signals don't work
fuel level gauge is on empty(full tank)
and the temp gauge isn't reading anything
I was wondering if this could be a fuse or if I just have a bad cluster
can someone please point me in the right direction
Re: instrument cluster not working
I had a somewhat similar problem. At random times my Tunerview II wouldn't turn on, the subwoofer wouldn't turn on, and and/or my gauge cluster didn't light up at night. I cleaned all my grounds and it solved my problems. Also make sure your battery terminals are clean and that it's showing the right voltage. That's just my experience though.
check fuse 10A in the under the dash fuse box https://honda-tech.com/forums/acura-integra-6/cluster-not-working-all-tried-new-one-3158508/ had a really similar issue 2 days ago.
correct me if im wrong but isn't that suppose to be a 7.5 amp fuse?
so I cleaned all the grounds. replaced the fuse but now the only one not working is the mph gauge.
look at the little cover that shows where/what amp rating of the fuse. either way the speedo no working can be pointed to the VSS check the plugs for corrosion or an open in the wire
jOnW89
33
02-20-2010 04:03 PM
