How much paint will I need to repaint my integra?
Old 11-07-2002, 12:00 PM
EPIC TUNING
E-Rok's Avatar
Default How much paint will I need to repaint my integra?
I wanna paint my car type-r yellow with a comptech lip and MAYBE a ITR wing, so now much paint will I need? 2 quarts? also will I need hardner with oem honda paint?
Old 11-07-2002, 12:15 PM
Tomakit's Avatar
Default Re: How much paint will I need to repaint my integra? (rewsnaeht)
1 qt per 10hp you expect to gain.
Tom
Old 11-07-2002, 01:35 PM
smallttocs's Avatar
Default Re: How much paint will I need to repaint my integra? (Tomakit)
1 qt per 10hp you expect to gain. Tom
LOL
Old 11-07-2002, 02:31 PM
Fuuma0083's Avatar
Default Re: How much paint will I need to repaint my integra? (smallttocs)
depends... (don't know how much it cost for "phoenix yellow") but i would guess around $5 grand +/- a few $100
Old 11-07-2002, 03:39 PM
jdm_dc2's Avatar
A GRIP. Unless you have sposors like me that do it for free. (Paint-n-Place in OC) Close to a gallon on a 2 door. And you need more than paint. Paint, reducers, hardners, etc...
Old 11-07-2002, 06:14 PM
EPIC TUNING
E-Rok's Avatar
Default Re: How much paint will I need to repaint my integra? (jdm_dc2)
am i better off buying the aint and materials from ppg or whatnot instead of acura?
BTW I would think someone with 2000 posts would be mature enough to say something rude just because im adding a type-r wing, hmmm turbo b18b and type-r wing, soooo much rice
Old 11-07-2002, 07:00 PM
slimbo's Avatar
around 3.5-4 litres i think... i dunno what a quart is in metric measurments
Old 11-07-2002, 07:54 PM
punzak's Avatar
I think you'll need about 7 quarts. Where do I derive this number?
"...From one angle, the 240sx is purple, from another angle, its gold, then it's green. Staring at the car for too long has been known to cause color blindness in lab mice. We're told the paint cost $350 per quart. If you are keeping score at home, seven quarts were needed."
- Dan J. Gardner (Sport Compact Car, Dec. 2002, pg. 180)
Old 11-07-2002, 09:25 PM
Solipsist's Avatar
4 to 5 Qts for a 2 stage paint job. (with clearcoat) Also factor in the type of paint that you will use. I use STANDOX on all my customers cars. Check out my site.
http://www.memorialauto.com
Old 11-08-2002, 12:00 AM
IntEGNYC's Avatar
Default Re: How much paint will I need to repaint my integra? (TEXASLS95)
Enough to cover the car.
Old 11-08-2002, 04:11 AM
Ricky Rojales's Avatar
Old 11-08-2002, 04:13 AM
MiraiZ's Avatar
Default Re: How much paint will I need to repaint my integra? (P)
6 or 7 cans of spray paint...or 1 bucket of house paint
[Modified by MiraiZ, 10:14 PM 11/8/2002]
Old 11-08-2002, 06:17 AM
Red!ine's Avatar
Default Re: How much paint will I need to repaint my integra? (MiraiZ)
I don't remember I think I used 2 quarts of paint, 5 quarts of clear? I think my gun holds 1 quart of.. liquid, and that's how much coats i used.. so.. yeah.
Sorry I'm in a different world at the moment.
Old 11-08-2002, 06:21 AM
Red!ine's Avatar
haha.. Actually i think it is kinda rice trying to make a non-type-R look like a Type-R. But if it makes you happy go for it!
Old 05-20-2016, 06:37 PM
Rusbin's Avatar
How many spray cans do i need to paint my acura integra 1995 4s
Old 05-20-2016, 06:40 PM
Rusbin's Avatar
But i mean what type of paint i need to use though,?
Old 05-20-2016, 06:53 PM
Rusbin's Avatar
Thanks for y'all advice guys,!
Old 05-26-2016, 08:18 AM
UndergroundTrev's Avatar
Lots of people leaving smart comments on a legitimate question. I was hoping to see a good answer since I'm planning on painting mine soon.
Old 05-26-2016, 10:58 AM
MotorMouth93's Avatar
1-1.5 gallons sprayable (after reduction) is fine if you're just spraying the outside of the car in one go, but if you plan on doing the insides of the door panels, door jabs, engine bay, etc. then get an extra quart or two.
Too much is better than not enough, if you spray the car, run out, and order more you'll have to blend the panels since the color will vary slightly. If your paint comes in multiple cans make sure to mix it all together in a big bucket before you spray, otherwise it won't match perfectly. A cheap 5 gallon bucket with a lid works good for this.
For the clear coat, the quantities are about the same.
Nothing worthwhile comes in a rattle can. If you're going to use that garbage, it'll probably take 10-15 cans, which is about 1-1.5 gallons. But it doesn't matter because you can always stop and go buy more.
Old 05-26-2016, 10:40 PM
Shit Posts: 15
JDMswagSerf's Avatar
Depends on the color your spraying and the current color of the car undergroundtrev.
Same color, just repsray. 1 gallon of RTS paint. Or 2 quarts of paint that mixes 1:1(1gallon total)
Spraying differnt color, 1.5 gallons RTS paint or 3 quarts of paint that mix 1:1.
1 gallon of clear.
Also depends as said above, it will bary if your painting just the car body or inside also.
My numbers are given from just spraying the body.
Do some more research rubsin, tons of videos of rattle can paint,
Old 05-27-2016, 12:46 PM
fcm
Old Fart
fcm's Avatar
It took 2 gal. to paint my 94 RS, 2 door, we did the door jambs, and inside door panels, not much more then a drop left over. 94
Old 05-29-2016, 10:44 AM
Fish Twig
tony_2018's Avatar
depends if you plan on laying primer or if you're just gonna sand and paint.
JustDoingMe
Paint and Body
04-02-2012 10:35 PM
acatak
06-08-2003 03:41 PM
pregunta
11-28-2001 08:40 AM
Quick Reply: How much paint will I need to repaint my integra?
