how to install custom integra foglights
custom integra headlights as foglights:
materials you need: socket wrench with extension wrench bolts, nuts, washers 4 L shaped brackets and 2 straight brackets 94+ integra low beam headlights 9005 or 9006 sockets electric tape heat shrink solder iron and solder power saw table vise hammer ( if needed) chisel ( if needed) JB weld ( if you break anything) silicon caulking masking tape hobby knife hand saw C-clamp (if needed) *patience*** 1: cut away the bumper area where you would usually put the stock raybrig foglights at with a hack saw. trim about 3mm off the corners where there are 2 holes for the stock foglights. do the same with the other side. http://www.imagestation.com/picture/...7/fa2794c1.jpg "http://www.imagestation.com/picture/sraid95/p6ddd50b04a84d8c1b2a8a021f83ed877/fa2794c1.jpg.orig.jpg" 2: loosen the bolt for the horn on the passenger side and pivot the horn as far as u can over to the right side of the car. be sure not to pivot it too much or else the wire that connects to it will be feeling tension and you don't want to end up with a broken wire. 3: now on to the headlights. crack the plastic housing and remove the metal piece that contains the levelor, high beam and the low beam. use your power saw and saw off the high beam and the top corner on the other side of each projector in yellow is the side with the high beam which was sawed off. and the black lines are where the corners used to be. u have to saw those corners off to make room to fit it into the grill area. in red are edges that you have to file down to make a flat surface for the Lshaped brackets. ( i used a power saw to saw it off) http://www.imagestation.com/picture/...8/fa2794b4.jpg "http://www.imagestation.com/picture/sraid95/pa68972922ab5c7917c4cd0e6ceab66a8/fa2794b4.jpg.orig.jpg" 4: now is your time to test fit. the passenger side should have enough room in the back to fit the projector after you move the horn to the side. however, on the driver's side, the rods that run horizontal across the front of the radiator will be blocking the bulb socket once you have the bulb in the projector. in order to fix this. u will have to chip a little off the tabs on the bulb itself so you can fit it into the projector from a different angle that wouldnt interfere with the radiator rods. i used a wire clipper to chip it off. NOTE: if you use 9005 bulbs, the angle might be different and might not require chipping the tabs. also if you take off the black plastic blacking that is bolted to the high beam by 3 screws and replace that with the one on the low beam, you might not have to modify the bulb. i used 9006 bulbs becuz the rubber ring is the exact size in prevent water from getting in. ( didn't want to risk anything since its mounted so low). http://www.imagestation.com/picture/...8/fa2794d0.jpg "http://www.imagestation.com/picture/sraid95/p2b2c283549b967c1f6b17d40bd0651f8/fa2794d0.jpg.orig.jpg" 5: drill holes into the side of the projector to mount the Lshaped brackets and straight bracket. this step requires a lot of trial and error. so it really depends on how you cut your projectors. NOTE: you can also use the levelor that comes on the integra housings for your custom foglights. just remove them ( i believe they are attached by 1 or 2 screws) and just screw them down to one of the fins on the projectors. be sure to mask them before you caulk or paint. (shown in blue). http://www.imagestation.com/picture/...3/fa2791d5.jpg "http://www.imagestation.com/picture/sraid95/p59d72a2192cd72711c67f3a71c96d663/fa2791d5.jpg.orig.jpg" 6: after your done and SURE THAT EVERYTHING FITS ONCE YOU BOLT IT ALL ON YOUR CAR, mask your lenses with masking tape. start with the bottom and work around as you go up. this helps prevent the paint from seeping through the cracks in the masking tape and get on the lens. then use a razor blade ( hobby knife) to trace the edge where the lens meets the metal ring thingie that holds onto it. peel off the masking tape off the metal pieces and remove the ring and the lens carefully. http://www.imagestation.com/picture/...4/fa2856e5.jpg "http://www.imagestation.com/picture/sraid95/pf9f92c67ff0f5db51965d2bc8a4af614/fa2856e5.jpg.orig.jpg" 7: caulk the inside of the ring . best to flood it with caulking. then press the lens into the ring. some of the caulking will squeeze out over the masking tape . then reassemble the lense, ring and the housing together. wipe off the excess caulking off the masking tape on the lens before it dries. 8: JB weld, or whatever any area you feel might be weak. i applied JB weld all over the edges and the nuts and bolts for a good solid bond. wait for it to dry (takes a long time approx 15 hours). NOTE: best time to start working on putt those bulb sockets on the car. strip the wires, solder them. then heat shrink them. and then loom them up if not already. electric tape them up for a good water proof seal. ( you should install the foglight wiring harnesses, relay, and switch if you don't already have them on the car at this point) http://www.imagestation.com/picture/...7/fa2856e2.jpg "http://www.imagestation.com/picture/sraid95/pda9563ab74b6dda34a6873921f112b37/fa2856e2.jpg.orig.jpg" 9: now cualk the rest of the housing from the outside until you're sure that water won't seep in. it would be a shame to fix this problem since its a hassle taking it apart after this process. wait for it to dry ( doesnt have to be completely dry before next step approx 6 hours) 10: paint the housing with whatever color heat resistance paint you want. i screwed up and didnt used heat resistant paint. painting it will help prevent it from rusting or so i think. wait for you to dry. then peel off the masking tape on the lens. 11: your almost done. put the housings into the grill area. to get the bolts into the 2 holes on the corners, its best to jack up the car a little, go under and use your wrench from the back and a socket wrench from the front to bolt it down tight. i used 8mm bolts and nuts. 1 washer front and back for each hole. NOTE: removing the bumper might make mounting easier. 12: turn on your newly installed lights, and aim them to your liking. see where the holes on the straight bracket ( now a 90degree bent L shaped bracket) are aligned with the vertical fins on your bumper and drill a hole there. use bolt, washers and nuts to mount it. now your all set! if your foglights arent aimed so nicely. just remove your signal lenses, stick your hand in there and with both hands, move the housing around until it aims to your liking. this should bend the brackets slightly for minor adjustments. for big adjustments, you might have to drill new holes. be sure to wear gloves and turn on your lights when you move them around like this. http://www.imagestation.com/picture/...3/fa2794af.jpg "http://www.imagestation.com/picture/sraid95/p82660e80fc61efcd748bbf2dca8ba8e3/fa2794af.jpg.orig.jpg" now ur all done!!! post some pics so i can see your new integra headlight to foglight setup https://honda-tech.com/forums/images/smilies/emwink.gif http://www.imagestation.com/picture/...7/fa2856d5.jpg http://www.imagestation.com/picture/...3/fa2856cf.jpg Modified by tekstyle at 7:29 PM 12/29/2003 |
Re: how to install custom integra foglights (tekstyle)
it's not something i'd do, but nice guide and install anyways. https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
Re: how to install custom integra foglights (CycoVizion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycoVizion »</TD></TR><TR><TD CLASS="quote">it's not something i'd do, but nice guide and install anyways. https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
yup and fawken clean looking too! https://honda-tech.com/forums/images...s/emsmilep.gif |
Re: how to install custom integra foglights (Weapon)
w00t w00t. Very nice car and the instructions are very informative. https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
when do u do mine... https://honda-tech.com/forums/images...es/emsmile.gif j/k
Hey just curious , are those the stock turn signals? And also what front lip is that? Sorry for all the questions but thats a clean teg im also rollin Gsr...Are those the stock gsr rims?cant really see that well.Anyways thanks (pm me the info if you can)
Re: (radio1global)
yea man.... stock signals, stock gsr rims, and usdm type r lip, but i added a splitter.
Re: (tekstyle)
can you take pics during the day?
Re: (streetlights)
ok sure thing.
nice diy project. I'd do it if I didn't have to cut my bumper up.
Re: (Ninjaboi_on_X)
true, but my bumper was already cut up from the raybrig foglights i had before i even bought the car https://honda-tech.com/forums/images...s/emsmilep.gif
Re: (streetlights)
Re: (tekstyle)
Damn clean!!! https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (Blckteg96)
Re: (tekstyle)
nice diy job and thanx for the how-to
Re: (sExy_TinKY)
that was a pretty nice write up man... good job.
time to use those highbeams for something now... how about... Tailgate Blinders! https://honda-tech.com/forums/images...es/emsmile.gif |
Re: (Erik_Pb_Foot)
Congrats you get an A+ for today, nice wright up, now if i can only get some extra integra headlights....
Re: (InfamousDC2FI)
Awesome writeup. I'd like to see more pictures as well.
I might have to try this out since I just so happen to have some spare headlights and 9006 sockets laying around. I'm just unsure of cutting up my new bumper so soon. |
Re: (InfamousDC2FI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InfamousDC2FI »</TD></TR><TR><TD CLASS="quote">Congrats you get an A+ for today, nice wright up, now if i can only get some extra integra headlights....</TD></TR></TABLE>
dang I must have probably 3 extra Integra projectors laying around... but they will be going under the knife when I start my OEM HID retrofit. https://honda-tech.com/forums/images...es/emsmile.gif |
Re: (PatrickGSR94)
oh sweet!! mind if u post a few pics of the project when ur working on it? i m thinking about that myself for a while as well https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images/smilies/emthup.gif
So the projector is just exposed like that with no casing? Wouldn't rocks and road debrit crack the glass?
Re: (loxllxol)
yes debrit and flying rocks might crack the glass, but that same goes for all other foglights OEM or aftermarket which are also made of glass. but for 35 bucks, i can save 130 bucks compared to OEM, and it works hell of a lot better than no name imitation foglights https://honda-tech.com/forums/images...es/emsmile.gif
Re: (tekstyle)
thats awsome bro i love that maybe I can try that on my car here it is with factory fogs http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg
Re: (JdoggsGSR)
i used to have factory fogs... selling them too right now https://honda-tech.com/forums/images...es/emsmile.gif
