RC injectors
Old 02-05-2002, 05:50 AM
New User
b20b's Avatar
Default RC injectors
What is the difference in the high rated ohms and low? Are the saturated better? This would be used for turbo. Thanks
Old 02-05-2002, 09:28 AM
New User
b20b's Avatar
Default Re: RC injectors (b20b)
anyone?
Old 02-05-2002, 09:14 PM
t
t's Avatar
There are two types of injectors, saturated and Peak&Hold injectors.
When measured across the injectors with an ohmmeter, you will see either 2-3ohms, low or you will see 12-13ohms, high.
You get the injector type according to which ecu you will be using. The easiest way is to measure the injectors you have now and get the same resistance injectors in your desired size.
2fast4uhonda
02-27-2013 12:46 PM
RACEPAK
04-29-2010 01:42 AM
Quick Reply: RC injectors
