PLEASE HELP ME!! car wont start, spark plug issue
i was performing a compression check on my car and i went to put the spark plug wires back in and one broke so i went to get a set of those crappy duralast wires and i know theyre making contact, but are there any ways i can check an see maybe my distributor isnt getting juice? it cranks just doesnt start idk im an idiot at this stuff i guess but i really need help!!
Re: PLEASE HELP ME!! car wont start, spark plug issue
well i plugged a spark plug into a wire and set it on the valve cover cranked it and no spark!
Old Fart
"Set it" on the valve cover?
You need to make sure the spark plug is grounded, "setting" it on the VC is no guarantee it will ground properly. 94
http://www.tegger.com/hondafaq/badse...al-arcing.html
You need to unplug the connectors from the distributors before doing the comp test, to prevent power from getting to the coil in the first place.
it's not the fact that it's painted. the valve cover doesn't actually make metal to metal contact with the motor because of the seal and grommets. the only thing grounding it to the chassis is the tiny 16 gauge wire.
Old Fart
It has more to do with the paint, and if all you have is a 16ga wire grounding your VC, fix it.
The "stock" VC ground, [Sub Ground Cable] would easily handel the load of a spark plug, it's the paint, trust me. 94
well then. i retract that statement
and yea, i was thinking about the other little wire that comes off the vc ground. that ones more like an 18 gauge though. but yea, the vc is probably something like a 10 or 12 gauge
Gotta problem with my start of my car it cranks but doesnt
Turn on I have a 91 ef with a b1 swaplooking to change everything
To obd1 if any could help I would be gratefull
