Help!! timing belt problem ASAP
I have a LS and puting a turbo on it, i had to take my cams out in the process. My tensioner bolt is stripped and wont move. Even when it does move it feels like its all the way tightened. When i move my crank pully to tighten the belt and make sure it is on all the teeth it skips teeth. I dont know what to do here to get the timing belt tighter. Any advice would be greatly apreciated.
THANKS |
Re: Help!! timing belt problem ASAP (yisoulja)
Cut the head off the tensioner bolt and thread it out.
The tensioner bolt needs to be loosened to tension the belt, and then retightened. You cannot tension the belt with the tensioner bolted down tight. |
try the extraction kit from sears. before i knew about it i just welded on a nut and it broke loose like butter. when the bolt is loose, it should move easily with the spring if you push it.
Re: Help!! timing belt problem ASAP (XDEep)
how much does that kit frm sears ost and what all come with it
try the extraction kit from sears. before i knew about it i just welded on a nut and it broke loose like butter. when the bolt is loose, it should move easily with the spring if you push it. **soldering works great for stripped nuts that arent torqued in very hard |
Re: Help!! timing belt problem ASAP (ls_teg)
man 19.99 is wayyy easier.
Re: Help!! timing belt problem ASAP (Rtzx9r)
ya in order to get a good angle to weld at, i had to remove the motor mounts and lower the motor until it cleared the inner fender
