HELP plz. CEL, P4 and ABS Codes
94 Integra LS, auto.
Thing ran great for about 2 months Now it throwing the following codes: CEL 10 IAT - intake air temperature sensor 14 IAC (EACV) - idle air control valve 3 MAP - manifold absolute pressure sensor 7 TPS - throttle position sensor P4 1 8 13 14 and the ABS also blinks. Any advice besides setting it on fire? Thanks all. |
Re: HELP plz. CEL, P4 and ABS Codes
bump
May be a grounding issue. There are too many things and all at once.
Originally Posted by tepid1
(Post 47715931)
I agree (and hope) that it's all related to a since issue/fix. Thanks for the reply and I'll update on how it goes this weekend. |
Anyone else?
Just collecting things to try for this weekend. Thanks |
Find it?
(Post 47729240)
Find it?
But had a buddy who's a mechanic come over and said he thinks it's the head gasket is gone... He's bringing over a compression tester from work tomorrow, so we'll see how it goes... |
Did a compression test and #4 had compression but 1-3 did not make the gauge move at all.
Buddy said it might be a blown head gasket... Said timing might also be an issue... but all of the sudden on the timing? |
Did the car overheat? did you rev it up hi? Do you have another ecu for it by chance?
Originally Posted by Manny 77
(Post 47732962)
I replaced the hose and topped off the coolant and was running for a while, in limp mode with all the codes but now won't start at all. This is my nieces car so she probably drove it for 20 miles while on fire :( |
Also, after checking it looks like it has no coolant in it now... no puddle under the car nothing on the inside that I can see?
Gasket is blown hopefully no damage to head or piston rings but i highly recomend you take that head to a machine shop before you put everything back on also new water pump seal bearings timing belt and tensioner as well...gl
About the abs code, find which code is giving you and i tell u which sensor u gotta replace
(Post 47733023)
