94 Ls wheel stud question plz
Old 11-17-2007, 09:56 PM
1stgenboost's Avatar
Default 94 Ls wheel stud question plz
tommorow i got to replace 3 wheel studs on the front of my buddys 94 LS ive heard there a real pain in the *** to fix can anyone tell me please how to get them out and in?
Old 11-17-2007, 10:18 PM
bump
Old 11-17-2007, 11:28 PM
denraweb's Avatar
Default Re: (1stgenboost)
It's not too hard. I know you have to grind down one edge of the top of the new studs to get them in easier. Otherwise, removing the hub would be your best bet.
Old 11-18-2007, 08:50 AM
my95dc2's Avatar
if you grind some of the spindle/hub area behind the brake shield on the side facing the door, it gives u just enough room to slide a new one in w.o grinding the stud, theres and article somewhere ill find it.
Old 11-18-2007, 09:21 AM
that would be great! so you all think that removing the hub is the best way to do this?
Old 11-18-2007, 10:21 AM
one last bump
Old 11-18-2007, 03:16 PM
ok well i just got back from looking at it and the notch idea seems good but i dont know what tool would best suite to make suck a notch. i can see using an angle grinder but im affraid that i would take to much out of it and it would throw it off balance? is that possible.. i also got a hub puller from autozone i think i wanna try it that way but im not 100 percent on it. do i just leave the axle nut on and go ahead and just start pulling the hub off? and more in depth ideas would be great. im broke lol and he is paying good to have this job done by tommorow the latest so any and all advice would be awesome
Old 11-18-2007, 03:36 PM
IN VTEC's Avatar
You'll want to remove the axle nut. You'll yank the outboard joint out with it if you leave the nut on.
I removed the drive shaft when I did mine just so that it wouldn't hang up on the splines.
Old 11-18-2007, 03:39 PM
so if you remove the nut then what holds the hub down from pushing out? the kid tried to do it without me there and used the puller on it and it just pushed the axle threw the hub and the hub stayed firms as can be
Old 11-18-2007, 08:18 PM
IN VTEC's Avatar
I didn't use a puller. I used a slide hammer with that puller adapter that you have.
Old 11-19-2007, 08:38 AM
ok i can see that, im not sure you would adapte a slide hammer with the hub puller but i can take a look at it. also another friend of mine said that you can take a socket that fits and place it on the inner ring of where the axle splines are and hit that with a hammer untill the hub pops off, are you familiar with that technic?
Old 11-20-2007, 11:46 AM
bump
honda416
07-07-2012 09:30 AM
B18Chonda
Audio / Security / Video
06-03-2008 06:34 PM
EK FLY
04-05-2006 10:43 AM
Cuong-nutz
04-13-2005 07:32 AM
sokenciviceg9
07-17-2003 01:21 PM
Quick Reply: 94 Ls wheel stud question plz
