help blowin fuse's
i took some altezza lights and painted them with translucent red paint. when i put them on last night they worked grest but when i hit the right turn signal it blows my signal fuse and i cant fint the hazard light fuse to replace it cause it blew out too. help wtf is wrong with my car. its a 1994 itr ls.
Re: help blowin fuse's (dubxl152)
Lemme get this straight...you painted the lenses, and the fuses blew? Sounds like a wire is shorting to ground. Get out the continuity tester and start testing around the tail light wiring.
Re: help blowin fuse's (TimoneX)
thats pretty much what happened. and where can i find the hazard light fuse i looked in the fuse box and there was no referance for it. its a 1994 itr ls
I don't know the fuse off the top of my head, but I believe it's number 19...10 A fuse I think. If not, check all the others.
