H&R Sport and Koni Yellow Heights?
Ok, if you haven't guessed, my car is on H&R Sports and Koni Yellows.
I live in the hills, so my car scrapes a LOT, even without a front lip. I want to raise the car in the front via the 3 perch settings, currently it's on the middle perches. I have 3 choices I guess: 1) Raise the front 2) Lower the rear 3) Raise both Would the car look odd if I did 1 or 2? I forgot how much of a difference each perch setting is. Here are some pix to give you guys an idea of what it's like now... http://www.bol.ucla.edu/~tli2001/Carpix/Car1.jpg http://www.bol.ucla.edu/~tli2001/Carpix/Car2.jpg http://www.bol.ucla.edu/~tli2001/Carpix/Car3.jpg Any helpful input would be great, especially from those with my same setup? |
Re: H&R Sport and Koni Yellow Heights? (i0o0ll0o0i)
I personally think it looks good with the back slightly higher than the front, so I'd say raise the front a little and the back a little bit more than that. Or just put the back up a little and leave the front the same, but if you do that I'd guess it will probably still scrape.
Re: H&R Sport and Koni Yellow Heights? (sean96gsr)
I'm pretty sure the stock perch height is the highest you can go on the Neuspeed Konis, and I know that for sure on the regular Koni yellow shocks. With H&R Sports and normal Koni spring perches set at stock in front and lowest in back (15mm lower from stock), this is what mine looks like:
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D I can't go any higher in front, but I could go as much as 30mm higher in back (15mm higher than stock perch height). I also scrape my bumper from time to time, but it's black so I don't care. |
Re: H&R Sport and Koni Yellow Heights? (PatrickGSR94)
Really, I thought there were more perches available, but I guess I am wrong.
PatrickGSR94 - are those 205/50/15 tires? Somehow your drop looks different than mine. |
yep 205/50-15... I just got new Yokohama AVS ES100's in that size, they look and perform HELLA better than those Nankangs I had before. Here's the only pic I have, after it was hit Saturday, and after I stripped the paint off the wheels... car is in the shop as we speak, and I will be repainting the wheels the same color after it gets out of the shop:
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D |
Speaking of perches...do i have any? sorry i am a little ignorant in this respect and i don't mean to jack the thread...i have H&R OE with bilsteins.
Re: H&R Sport and Koni Yellow Heights? (jabroni95gsr)
Koni Sport yellow shocks are the only ones I know of that have notches/c-clips for the spring perches to sit on. The Koni spring perches are not welded to the shock body like on most OEM-style shocks, and the different notches allow you limited height adjustment.
I would raise the front first if your hitting. PatrickGSR94 how much is your car lowered from stock? I am trying to gauge "drops" and I like your ride height. Just curios if that is 1.5", 2" or more. sorry to jack the thread. [Modified by MattG, 8:58 PM 3/12/2003] |
Re: H&R Sport and Koni Yellow Heights? (MattG)
i think patricks car is prob a 2" drop or maybe slightly more based on how nicely it sits on those 50 series tires...
on a side note, patrick, i like the rims stripped! (back to stock)...not that it matters what i think https://honda-tech.com/forums/images...s/emsmilep.gif |
drop the rears, truuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuust me
id post pics of my car, but then id be such a post whore. |
Re: H&R Sport and Koni Yellow Heights? (SilverB18C1)
does anybody have mud flap scrappage??? mine scrapes a lot, im runnin tokico blues/h&r sports on stock dookie rims (sorry no pics, i dont know how) and those bad boys are always scrapin. anyone have this problem? it doesnt really bother me that much but sometimes it gets a little irratating..
Re: H&R Sport and Koni Yellow Heights? (gumbybum)
if you raise it its gonna look like shit. u should add an iron lip. akakak.
PatrickGSR94 how much is your car lowered from stock? I am trying to gauge "drops" and I like your ride height. Just curios if that is 1.5", 2" or more. on a side note, patrick, i like the rims stripped! (back to stock)...not that it matters what i think http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D does anybody have mud flap scrappage??? mine scrapes a lot, im runnin tokico blues/h&r sports on stock dookie rims (sorry no pics, i dont know how) and those bad boys are always scrapin. anyone have this problem? it doesnt really bother me that much but sometimes it gets a little irratating.. http://www2.msstate.edu/~pks2/MyIntegra/low_hand.jpg This is another reason why I think the H&R springs are too soft for the amount they drop. I think the mudguards wouldn't scrape as much with stiffer springs like custom rate GC's, set to about the same drop as what I have now. |
I'm pretty sure the stock perch height is the highest you can go on the Neuspeed Konis, and I know that for sure on the regular Koni yellow shocks. Also when I intalled my ITR springs and Koni Yellos I set the perches on the middle stock height and got a pretty even drop all around. However that's probably a bit different with the H&R sports. |
Re: H&R Sport and Koni Yellow Heights? (Eva01)
My mudguards scrape too, but I don't care, as long as it's nothing important.
I don't think I can raise the front if what PatrickGSR94 said, so I'll look into dropping the rear and see if that helps. All good about jacking the thread, as long as useful information is being shared. |
Patrick, in the instruction sheet I got w/ my neuspeed Konis they illustrate that the middle pearch is actually stock height. So there are two notches to go lower and two notches to go higher. https://honda-tech.com/forums/images/smilies/emwink.gif |
Patrick, in the instruction sheet I got w/ my neuspeed Konis they illustrate that the middle pearch is actually stock height. So there are two notches to go lower and two notches to go higher. |
Re: H&R Sport and Koni Yellow Heights? (BlkGSR)
Patrick, in the instruction sheet I got w/ my neuspeed Konis they illustrate that the middle pearch is actually stock height. So there are two notches to go lower and two notches to go higher. Would someone please verify this information? I am looking to get a strut that has an adjustment setting higher than stock. Thanks. |
