gsr ys1 lsd cable trans help w/ half shaft, oil leak, & axle popping?
okay so i purchased a ys1 gsr cable trans off a friend i am running a 93 gsr intermediate shaft seal in the tranny part# 91205-pl3-b01, is the part number diffrent between lsd and non lsd? I am running brand new 96 ls axles and the female driver side axle with the dc male intermediate shaft, not sure if axles/ intermediate shaft are compatible with the tranny? they work but maybe not correctly?
the problems i am having is that the intermediate shaft keeps draining fluid out badly, and i also am having a problem, when i take sharp turns from a stop, release clutch, and press the throttle, the axles begin to make a popping noise and click the wheel as im in the turn. i am running gm syncromesh fluid with rear diff additive mixed in as well. iv heard the popping noise may be because of a bad diff, any help would be great, to find what possibility the problem may be.
CapnKrunch
09-01-2010 06:29 PM
