GSR or Type R?
HI guys an gals! I'm having a bit of a dilemma... Soon I'm going to be purchasing a motor for my 95 Integra LS. Now I'm not new to the Honda scene and have done many swaps but I need some persuasion. My question is should i get a Type R motor or GSR? My goal at first was to go for authenticity since I have the Type r front and i wanted the motor number B18C... But I was told i could go a cheaper route and buy a GSR and port and polish and get stage 1 cams and it would be the same thing which didn't seem right to me. H-motors has a whole type R swap with lsd tranny for $3500.00 as I could get a good GSR for $13-$1600 not including tranny or ECU. So now I look to you guys...Help!:thud:[IMG]http://img713.imageshack.us/img713/5586/1001074u.jpg Uploaded with ImageShack.us[/IMG]
Re: GSR or Type R?
What kind of ending HP are you shooting for? And how come your ruling out B20V?
I was looking on Hmotors website and their 96-97 ITR motor is $3600+shipping (so figure near 4k) Plus motor mounts...clutch...etc....all of the things that should be done prior to dropping the motor. I'm thinking after install that will have set you back at least $4700... Just to steep for me...I'd go GSR and build it over time. Just my $.02 EDIT: No offense, love me ITR...but a lot of money can be saved on the B20 or GSR route. And you'll be just as happy. |
Re: GSR or Type R?
no such thing as a type R front, I think you mean JDM front
b18c (JDM Motor) can be either from a type R or GSR... so I dont see the whole 'authenticity' aspect here haha. b18c1 - gsr b18c5 - type R type R motors are over rated. Get yourself a gsr, put some bolt ons and heavy cams, and you will wizz past a type R. Type R's are so friggin torqueless compared to built gsrs :D especially with the dual stage intake manifold that EVERYONE hates..... except me |
Re: GSR or Type R?
Thanks for the reply's guy much appreciated. I was leaning more toward the GSR just for the fact that I would have some $$$$ left over. So that will help me with my next goal to safely rev to 10K and big cams:P . sorry about the Type R front thing...Type R on the brain lol
Re: GSR or Type R?
jst get the jdm b18c gsr or as some pple may knw as the SIR-g
and build it ,in the long run you'll be raping type r's ! :) getting bigger cams etc goodies ! |
Re: GSR or Type R?
I havent had a b20 but and I am still running my 98+ jdm b18c. I have never been happier with the decision. One thing to consider is the 98+ has a 4.7 fd. You will really notice the steep gears. I bought mine from JDM Online and they had great customer service.
Re: GSR or Type R?
I love my GSR! ITR motors scream "steal me" just because the are rare. For the price that they cost they are over rated. Good luck with your build.
Re: GSR or Type R?
Thats a jdm front end...i would go with a gsr..cheaper...and if a gsr with bolt ons aint it..turbo it
Re: GSR or Type R?
Even though I've never owned either, I'm gonna go ahead and say GSR. The money you save could be used to make the GSR out run a Type R easy.
Re: GSR or Type R?
Over the years the consensus has seemed to be, if you're going to drop it in and run it go ahead with ITR, otherwise, save your money and use it to build the GSR. The GSR makes a good foundation, and you're probably replacing or modifying everything that makes the ITR unique anyway..
Re: GSR or Type R?
gsr dude save money and upgrade the gsr
Re: GSR or Type R?
i go gsr n/a pushin like the 290hp nsx i would be happy or just go turbo.
Re: GSR or Type R?
It gets called a "JDM" front end but plenty of JDM Integras had the round light front, just not Type Rs.
Re: GSR or Type R?
Majority vote so far GSR! One thing I did liked about the type R swap is it came with the S80 LSD trans. And they were under 20K miles with warrenty. Dose anyone know of a cheap but good site to look at GSR's??? Thanks for the replys guys!:thumbup:
Re: GSR or Type R?
If you have the money just do the type r swap. If not GSR. Its as simple as that. You can upgrade your cams in a gsr but you also have to replace your valve springs. So it just depends on what you want. If your car is a DD you will get better mpg with the gsr tranny which is why i got a type-r motor and put in a type-r lsd in my gsr tranny. As for other sites i dunno. i bought my motor from the acura dealership.
Re: GSR or Type R?
Go to Hmotorsonline.com best place to get a motor with less
Miles on them & trust worthy ftw!! |
Re: GSR or Type R?
LOL there is such a things as a type r front end... it simply comes off the type r from japan, and when they refer to jdm front...they usually mean the jdm gsr. LOL theres a different in jdm gsr headlights and type rs... LOL funny ht people...anywho...
i say you go gsr, simply because if it ever comes to it you can bar it.. im not so sure about the type r motor, too much confusion i dont even know whats going on anymore. either way you cant go wrong. i mean if you have the money then by all means get the type r. if budget is a problem go with the gsr. gsr will be easier to boost, itr is superior for that engine response, all motor setups. but the gsr could do the same its just gonna take some work. |
Re: GSR or Type R?
Originally Posted by LovinmyTypeR
(Post 45071295)
you get a LOT of upgrades in the itr vs the gsr swap for swap *increased resale *itr cams *itr VT *11:1 compression *a decent exhaust manifold *single runner intake manifold *helical LSD *closer ratio gear box if you were to upgrade a GSR you would spend the extra $1000 which is the difference in the swap price on just the LSD, cams and intake manifold. if you get the gsr lsd it's +400 which still makes the math the same and we haven't even talked about labor, the vt, gear ratio improvement or bump in compression gsr is probably the better buy for boost since all you'll change is the intake manifold for a NA drive the ITR is a better buy mpg is roughly the same. gsr got about 320 miles a tank, itr does too |
Re: GSR or Type R?
gsrs all day. Ive seen type-r's with bolt-ons run mid to high 14's and a gsr with boltone's running low 14. If lets say you get a gsr swap 100%complete for $1500 and for $2000 more( cince the R is 3500) you can be much faster than the R.
Re: GSR or Type R?
Originally Posted by danielblushtein
(Post 45076849)
Re: GSR or Type R?
Not trying to beat a dead giraffe wolf w/a stick but wouldn't a b20v be a much better value then ITR or GSR? How come I'm the only one that mentioned this? I'm not high right???
Think about it: If I had $3500 bones thats EXACTLY where I'm going. Can you imagine what $3500 would do to a B20V compared to paying the same price for a stock ITR motor, or even mildly upgraded GSR motor for that matter? And the torque....OMG <3 Built B20V/GSR Tranny/ITR LSD= Winning |
Re: GSR or Type R?
Originally Posted by PreyStayShun
(Post 45077479)
Think about it: If I had $3500 bones thats EXACTLY where I'm going. Can you imagine what $3500 would do to a B20V compared to paying the same price for a stock ITR motor, or even mildly upgraded GSR motor for that matter? And the torque....OMG <3 Built B20V/GSR Tranny/ITR LSD= Winning also this "torque" difference is literally a few ftlb you want to be fast start buying turbo parts, it's as simple as that. a stock gsr or itr will live an extremely long life at 300whp boosted if the parts are high end and the tune is spot on |
Re: GSR or Type R?
Originally Posted by racebum
(Post 45077527)
the b20v will make more power all else equal. they just happen to have the nick name "time bomb" for a reason. an itr engine can run to 8500 and often lives 150k+ miles. a b20v is considered a long liver if it makes it 10k miles. when you read posts about guys saying "i ran a b20v for a year" this is often why it was just a year
also this "torque" difference is literally a few ftlb you want to be fast start buying turbo parts, it's as simple as that. a stock gsr or itr will live an extremely long life at 300whp boosted if the parts are high end and the tune is spot on Longevity for the win, so I'm back to my previous GSR vote I suppose. |
Re: GSR or Type R?
type r if your going for the fact of having a type r but be careful of who you pop your hood to. if money isnt an issue type r all day but if your on a budget gsr and over time build it so it doesnt hit you all at once.
Re: GSR or Type R?
If you plan on upgrading any of the internals I would just save your money and go with the GSR.
