Gsr intake maniflod.....Good/Bad
Old 12-01-2005, 06:08 AM
Karizmah's Avatar
Default Gsr intake maniflod.....Good/Bad
Hi im wondering if the "Snail" Mani. is all that bad.
Im thinking about upgrading to a skunk 2 pro series
but im not sure if it's worth it.....What do you guys think?
Old 12-01-2005, 06:10 AM
Will you make something up for me please?
shamoo's Avatar
Default Re: Gsr intake maniflod.....Good/Bad (Karizmah)
It's fine for up to moderate power. Anything more and it will be restrictive. Keep in mind that anytime you are making more power (or need to make more power), you need to keep all air restrictions (and sometimes fuel) to a minimum. The intake manifold is one of them.
Old 12-01-2005, 06:28 AM
Kendall's Avatar
The stock manifold can be ported for excellent flow, but the head itself will become the biggest restriction at this point. It's usually much easier to upgrade to an aftermarket manifold.
Old 12-01-2005, 07:08 AM
1JDMDOMINICAN's Avatar
I was told that there is a way to remove the secondary butterflies in the GSR intake manifold...i've been doing some research into it cuz I plan to do it to mine if possible...if not, then I'll be going for a Skunk2 i/m
Old 12-01-2005, 07:39 AM
gsrious's Avatar
Default Re: (Mugen-DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">I was told that there is a way to remove the secondary butterflies in the GSR intake manifold...i've been doing some research into it cuz I plan to do it to mine if possible...if not, then I'll be going for a Skunk2 i/m</TD></TR></TABLE>removingthe butterflies won't yeaild you any gains in the high rpm range... it will still flow the same.
however, removing the butterflies will hurt you in the low rpm, so there is no point in removing it.
Old 12-01-2005, 09:00 AM
Karizmah's Avatar
Thanks alot guys. I dont plan on going turbo however some bigger cams are def.
a forseeable option. Does anyone know if the intake would sound any different?
Old 12-04-2005, 01:45 PM
Now as far going turbo, would it be better to go with a Skunk2 intake manifold as opposed to using the OEM GSR manifold when boosting the motor?
Old 12-07-2005, 05:02 AM
Karizmah's Avatar
I would assume the skunk 2 would be better all around due to a higher air flow.
Old 12-07-2005, 05:41 AM
originalg00kster's Avatar
Default Re: (Karizmah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Karizmah &raquo;</TD></TR><TR><TD CLASS="quote">I would assume the skunk 2 would be better all around due to a higher air flow.</TD></TR></TABLE>
Old 12-07-2005, 06:05 AM
gsrious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">Now as far going turbo, would it be better to go with a Skunk2 intake manifold as opposed to using the OEM GSR manifold when boosting the motor?</TD></TR></TABLE>when you are boosting(positive pressure)... the iab won't matter anymore... the iab can try to restrict flow but the pos. pressure in the mani will just go the other route into the engine.
all in all... i'd say if you are going to boost with gsr... atleast get a different mani that can outperform the stock mani's flowing rate.
Old 12-07-2005, 07:10 AM
TRE_'s Avatar
Default Re: (gsrious)
I had a boosted gsr motor running 10psi with a stock IM and it made decent power.... put on a skunk2 IM and noticed quite a difference right away. i never had the oppurtunity to dyno the setup after the skunk2 install but i definantly saw more mid range power and the powerband felt "smoother" almost.
dices543
11-25-2012 08:25 AM
boostincoupe
06-06-2006 10:59 AM
Ratman
11
04-20-2005 11:39 PM
sloweredcivic
02-08-2005 07:17 PM
jdmjeff
17
01-13-2005 03:57 PM
Quick Reply: Gsr intake maniflod.....Good/Bad
