GSR cluster in an LS
anyone know if it is straight plug and play?
The gsr cluster is from a 95 and the LS is a 95. thanks |
Re: GSR cluster in an LS (Canttx)
it's plug and play. all 94-01 teg clusters are interchangeable. as long as u get the cluster for a manual, and the same cluster for an automatic.
I'm sure it will work... though you have to keep in mind, the GSR tach has 8100 redline and the LS tach has its redline at a much lower rpm. My advice to you is to not swap them out unless you have a motor swap in the works.
Re: GSR cluster in an LS (JSM)
thanks guys! exactly what i wanted to hear.
i hope ur not being a poser!!1!
Re: GSR cluster in an LS (DRAG lll INTEGRA)
no, no.. its actually not for my car(eg civic) im selling one to someone. So i guess he will be a poser http://images.zeroforum.com/smile/emsmile.gif
| All times are GMT -8. The time now is 08:43 PM. |
