Fidanza aluminum flywheel on a street driven Gizzer(GSR)....is it worth it or is it overkill???
Old 01-05-2006, 07:04 PM
1JDMDOMINICAN's Avatar
Default Fidanza aluminum flywheel on a street driven Gizzer(GSR)....is it worth it or is it overkill???
Like the post says, I want to order my flywheel and I was looking at the Fidanza flywheel and the Kaiten Karui flywheel. I was wondering, for a street driven car, is it worth getting the aluminum Fidanza flywheel or should I go for the lightweight steel Kaiten flywheel? reason I ask is because I have heard of aluminum flywheels warping after a while.
I plan to boost my car hopefully at the beginning of this summer...just wanted to know people's input as far as flywheels go.
The flywheel will be going on a 97 GSR Integra.
Old 01-05-2006, 07:11 PM
lVlemphizStylez's Avatar
Default Re: Fidanza aluminum flywheel on a street driven Gizzer(GSR)....is it worth it or is it overkill???
i personally wont touch anything shy of chromoly steel
Old 01-05-2006, 07:17 PM
so ur saying stick with the steel flywheel?
Old 01-05-2006, 07:20 PM
Default Re: (Mugen-DC2)
yes..chromoly steel ...nothing to sit and worry about...because i have heard of warping aluminum wheels as well as some brands where the teeth seperate from the disk because they are made in two pieces
Old 01-05-2006, 10:40 PM
Dartanian's Avatar
Default Re: (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">yes..chromoly steel ...nothing to sit and worry about...because i have heard of warping aluminum wheels as well as some brands where the teeth seperate from the disk because they are made in two pieces</TD></TR></TABLE>
On a daily driven GSR with bolt-ons or low boost, there is no way the car will make enough power to shatter or warp a flywheel. Stick with a trusted name brand and you won't have issues.
I have the ACT Prolite 8.8 lb flywheel on my boosted setup and I love it except for the difficulty getting traction in first and second gear compared to a stock flywheel.
Old 01-06-2006, 06:57 AM
Default Re: (Das Schmoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo &raquo;</TD></TR><TR><TD CLASS="quote">
I have the ACT Prolite 8.8 lb flywheel on my boosted setup and I love it except for the difficulty getting traction in first and second gear compared to a stock flywheel.</TD></TR></TABLE>
the car the aluminum flywheel seperated from the teeth on was a pretty much stock type r....and i dunno bout you...but thats certainly not a powerhouse...
Old 01-06-2006, 10:11 AM
Darth ModerVader
Padawan's Avatar
The Fidanza is an excellent choice, and is always my primary recommendation for a lightweight flywheel. Do a quick search here on H-T and you'll turn up many posts from members who have had positive experiences with the Fidanza / Clutch Masters unit.
Old 01-06-2006, 11:56 AM
Dartanian's Avatar
the car the aluminum flywheel seperated from the teeth on was a pretty much stock type r....and i dunno bout you...but thats certainly not a powerhouse...</TD></TR></TABLE>
And what brand was it?
Old 01-06-2006, 12:15 PM
fidanza...here is a case right here...
"i used a fidanza lightweight flywheel and the outer ring seperated from the inner part. i haven't heard of it on an itr flywheel. now i only use a one piece chrome moly flywheel that doesn't have any way to come apart. "
and Jun was the brand that was on the type r
http://ForumID=10&TopicID=2699...earch
Old 01-06-2006, 12:30 PM
Dartanian's Avatar
Interesting. I haven't heard a case of the fidanza failing. Good thing I have the ACT one then.
Old 01-06-2006, 01:52 PM
numotive's Avatar
i have a toda chrome-molly on my gs-r and i love it. haven't had any problems with it so far. its light, but not so light that the revs drop off instantly when shifting...
Old 01-06-2006, 02:36 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">The Fidanza is an excellent choice, and is always my primary recommendation for a lightweight flywheel. Do a quick search here on H-T and you'll turn up many posts from members who have had positive experiences with the Fidanza / Clutch Masters unit. </TD></TR></TABLE>
Absolutely. Fidanza also makes flywheels for Dinan
Old 01-06-2006, 05:27 PM
ProjectLSVTEG's Avatar
I personally like my ACT, but I am not going to say anything about the tohers as I have not used them. I love the ACT though.
Old 01-06-2006, 07:49 PM
HT Black OPs
00IntegrAllmotoR's Avatar
i already have a fidenza flywheel its going on my boosted project.
Old 01-08-2006, 10:45 AM
LOOKS LIKE i'LL BE LLOKING AT THE ACT STREETLITE AND THE KAITEN KARUI....THE TODA ONE SEEMS GOOD, BUT I DON'T THINK I CAN AFFORD 480 DOLLARS FOR A FLYWHEEL.
Old 01-08-2006, 10:51 AM
now, what is better...the 8.8lbs flywheel or a 9 lb flywheel? I know lighter is better, but for a street car, is 8.8 a little too much or should i not worry about that.
Old 01-08-2006, 12:05 PM
Sack Master's Avatar
No problems what with my fidanza flywheel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo &raquo;</TD></TR><TR><TD CLASS="quote">I have the ACT Prolite 8.8 lb flywheel on my boosted setup and I love it except for the difficulty getting traction in first and second gear compared to a stock flywheel.</TD></TR></TABLE>I developed the same issues myself.
Old 01-08-2006, 12:27 PM
Supersonicboost's Avatar
Default Re: (Sack Master)
I have the prolite (act) i love it its great cant say nothing bad bout anything else
Old 01-08-2006, 01:55 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">now, what is better...the 8.8lbs flywheel or a 9 lb flywheel? I know lighter is better, but for a street car, is 8.8 a little too much or should i not worry about that.</TD></TR></TABLE>
.2 lbs?
You won't notice the difference between the two.
Old 01-08-2006, 02:04 PM
coldfusion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">Absolutely. Fidanza also makes flywheels for Dinan </TD></TR></TABLE>
I had a Fidanza in my ex '95 M3 and never had a problem...
Old 01-08-2006, 02:30 PM
.Kevin.'s Avatar
go with the fidanza.... People that tell you its hard in traffic are idiots because either A im an amazing driver and do everything rite or B it isnt. and there are no problems with them, the only problem you could see is it cracking BUT that only happens if you have sick amounts of HP. mine has seen the track 3 times this year with over 35 runs and i have no problems
2kdrift
10-13-2007 06:29 AM
Boostage
08-17-2006 01:03 PM
Quick Reply: Fidanza aluminum flywheel on a street driven Gizzer(GSR)....is it worth it or is it overkill???
