Exhaust help?
Old 03-17-2018, 11:38 PM
Sunkenkarma's Avatar
Default Exhaust help?
So im swapping my swap from my 99 integra LS into my 97 GSR shell. The LS does not have any exhaust, as for the GSR. I keep reading that the GSR and the LS have different length exhausts? Which do I need in this case? B18B1 into DC2.
Old 03-18-2018, 08:34 AM
jdmark1's Avatar
Default Re: Exhaust help?
The only differences between those two exhausts is on an OEM exhaust setup. The GSR, 94-99, had the primary O2 sensor on the CAT itself while all other tegs had them on the A-pipe (which is the pipe between the stock exhaust headers and the cat). So a stock A-pipe for the GSR would be a bit shorter, while the CAT would be a bit longer. And vice-versa, the LS A-pipe would be a bit longer while the CAT is shorter. Everything before and after the A-pipe/CAT combo is the same, dimension wise.
F_dub7
01-23-2010 06:28 AM
ken'd
01-30-2006 08:04 PM
pete332
03-26-2003 07:56 AM
gumbybum
01-17-2003 03:29 PM
Never1st
01-08-2003 04:00 PM
Quick Reply: Exhaust help?
