ecu codes
first timer working on import check engine light on hear you can jump the codes i just dont know how where to put the wire to get codes heard very easy
search on how no threads on how just on what codes are thank for any help https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: ecu codes (b18c4dr)
96 gsr sorry
by your ecu there should be a blue plug that has two wires coming out of it. jump that plug by taking a wire and putting each end in one of the plugs. then turn you car to the on posistion and it should start blinking. the long blinks=10 the short=1. so if it looks like this !...!...!...!...!.!.! that would be code 43. once you get the code come on here and search for it.
thank you got the haynes book just didnt know the wire part really big help ill be back here soon https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
one of the wires coming out of the plug is brown i know that for sure. come back with the code and maybe ill help you out.
Re: ecu codes (tallyturbo)
go to the civic forum and look at one of the first 5 posts...they made the ecu code topic a sticky. Has all the codes, how to jump your ecu to pull the codes, ecu pin outs, etc.
Re: ecu codes (iH8RICERZ)
thanks for schooling me ill update after water goes away https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
thanks explains everything https://honda-tech.com/forums/images/smilies/emthup.gif
codes is (92) i think 9 long blinks and 2 quick blink
cold air intake can throw this sensor off evap sensor? what is the fix for this code https://honda-tech.com/forums/images/smilies/emthup.gif thumbup: |
i dont know the fix but was that the only code it was throwing? in other words when you got the code when it stopped blinking did the code that start blinking next the same?
repeats the same code over and over thanks
purge valve solinoid 152.00 dealer thanks for your input turbo
no problem. i hope you fix your car.
| All times are GMT -8. The time now is 09:30 AM. |
