Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Acura Integra (https://honda-tech.com/forums/acura-integra-6/)
-   -   door lock problem (https://honda-tech.com/forums/acura-integra-6/door-lock-problem-2382190/)
beastmaggot Sep 6, 2008 09:48 PM
door lock problem
the door locks stoped working on my 95 integra 2dr. a couple of weeks ago. i got a new control module since neither switches work, but i cant find the module any one have a good description on where it is or maybe some pics?
steveharrmr23 Sep 7, 2008 06:27 AM
Re: door lock problem (beastmaggot)
remove your drivers side door panel it is in there
1992TegGsr Sep 7, 2008 07:18 AM
Looking at your door from the outside of the car, like your about to get in the car, it should be around the top right of the door. Take the door panel off and look. Thats where mines located in my 92 Integra.
ls19integra95 Sep 7, 2008 08:04 AM
Re: (1992TegGsr)
exactly what 1992teggsr and steveharrmr23 said, take your door panel off and its behind it bolted to the inside the door, you wont miss it once you get the panel off.
steveharrmr23 Sep 7, 2008 08:36 AM
Re: (ls19integra95)
i know it is there because my old lady likes to lock the keys in the car and i got tired of locksmith fees so i installed a monotary switch that is like hitting the unlock button
beastmaggot Sep 7, 2008 12:01 PM
thanks for the help u guys were right. it was in the door. the module wasnt bad i had a bad power wire but couldnt check until i had a place to trace back from. thanks again
