DIY S2k button start /w cruise control harness
Old 01-18-2010, 09:09 PM
  #26
New User
Default Re: DIY S2k button start /w cruise control harness
i was woundering if i could do this same thing in my DA and use the CC
DAls-vtec is offline
  #27
dale m.'s Avatar
very helpful
dale m. is offline
Old 06-18-2010, 07:27 PM
  #28
GhettoBizzle's Avatar
Ive been plannin on doin this for a while..
Just havent found a button I like enough (Didnt even think of the S2K)
I think ill do this along with the remote start installation, That way Ill already have these wires out.
GhettoBizzle is offline
Old 06-18-2010, 07:40 PM
  #29
asianpoet's Avatar
Wow. I didnt know that you needed a write up for this just to start the car.. Considering I just did this cauase I was to lazy to figure out why my car didnt start.. (come to find out, that it was the clutch safety switch) I finally got around to it..
ofcourse I just run a 12v from the fuse to the connector that powered the starter.
asianpoet is offline
Old 06-25-2010, 12:08 AM
  #30
Dc295kid's Avatar
try this the other day didnnt work out i cut the ignition wire that goes to the fuse box black and yellow and then the light for my cluster didnt turn on what did i do wrong? i also have a alarm relay so i just tapped the it in to there
Dc295kid is offline
Old 08-31-2010, 02:12 PM
  #31
98_ssbp's Avatar
to anyone who has done this, are the starter and ignition wires in the same loom? i looked in one of the looms and found a black w/ yellow stripe wire and a white w/ black stripe wire. in another loom i found a black w/ white stripe wire. this is really confusin me! plzzzzz help my car is torn apart right now!
98_ssbp is offline
Old 08-31-2010, 02:51 PM
  #32
98_ssbp's Avatar
Need help now!!!
98_ssbp is offline
Old 09-29-2010, 03:09 PM
  #33
guywitaDA's Avatar
i tried this the other day also..... hooked it up the way the diagram showed..... nothing. i tried a few other options still no luck so i gave up..... can anyone show some light on this......
guywitaDA is offline
Old 05-31-2013, 06:01 AM
  #34
Great write up. I've finally decided to do this to my 98 so I went to the LKQ pulled a cc button because I use mine do I didn't want to lose it. Thanks for the write up solscud007 and thanks mtgtint.com for shedding light on not cutting the ignition wire
Datransporter is offline
carlosjdmcivic
20
06-07-2013 09:00 AM
ruffrhyder
05-26-2009 11:31 AM
808DB1
02-27-2008 07:12 AM
Solscud007
09-03-2007 11:56 PM
Imprezn
03-31-2003 08:42 AM
Quick Reply: DIY S2k button start /w cruise control harness
  • Ask a Question
Question Title:
Description:
