DIY: Moon cut valve cover for GSR, ITR heads.. Very detailed!
<FONT COLOR="Red"><FONT SIZE="3">DIY: Moon cut valve cover!</FONT></FONT>
Tools needed:
Valve Cover
Drill
1/8 bit
3 1/2" hole saw<------ May be a hair too big, I don't know for sure. I'll update l8tr.
Pilot bit holder thingy (don't know the exact name, sorry)
Hammer
Punch (or Phillips screw driver)
A buddy (or a vice)
Optional: A file to smooth down the edges.
Step 1: Locate your valve cover, remove it and get your tools ready to modify your valve cover!!!
What your starting out with. I used the pic as a size reference for the cam gears.
Step 2: Measure to find the center of the cams. To the center of the lil slot, it's 2 5/8", approx. May be a 1/16th off or so.
Step 3: Indent the valve cover where your going to drill, and drill a pilot hole. I made my indentions, using the hammer and a punch, about at the top of the lil ridge on the valve cover. Reference t3h pic plz.
Step 4: Put the hole saw on the drill w/the pilot bit. Using a buddy or a vice (I used my good friend Dan) secure the valve cover so it won't move, muster up some courage and start cutting the valve cover. Maybe you'll end up with something like this.
You know I gotta throw a thumbs up in there
Step 5: Optional: Using a file, file down the sharpe edges till they are smooth. Don't want to possibly knick your timing belt when you re-install your valve cover. his may keep you from possibly cutting youself too, but who cares: Your finger will heal for free, you'd have to BUY a new timing belt Plus chics dig scarzz
Step 5 (or Step 6 if optional step is used): Clean the valve cover. Don't want any bits of metal in your engine do you? I didn't think so. Clean it as best as you can.
And.................... Well, I did this about 30 mins ago, and I won't be installing my head untill next weekend, so no finished pics of it on the car, but I'll update whenever I can.
Hope this works for you guys. I didn't see a DIY detailed enough for my liking, so maye this will help somebody one day
If you see anything that could add to this DIY and make it more helpful, by all means, let me know and I'll change it.
Enj0y!
Modified by mac_24_seven at 10:16 AM 7/26/2007
Tools needed:
Valve Cover
Drill
1/8 bit
Hammer
A buddy (or a vice)
Enj0y!
Re: (gsrious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious »</TD></TR><TR><TD CLASS="quote">awesome diy. you should try to do a follow-up with the plastic cover to match that evenly.</TD></TR></TABLE>
Re: (b20acura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20acura »</TD></TR><TR><TD CLASS="quote">nice diy. post some pics of it on the motor.</TD></TR></TABLE>
Thanks.
ANd I shall. it'll go on next weekend, but this weekend it's getting painted
Thanks.
1 Post
Re: DIY: Moon cut valve cover for GSR, ITR heads.. Very detailed! (iH8RICERZ)
Very nice DIY article. I have a spare valve cover laying around and think I'ma try this. Props to you
Re: DIY: Moon cut valve cover for GSR, ITR heads.. Very detailed! (gsl_05)
DIY: Painted valve cover.. Part 1
This isn;t really a DIY, per se', it's more of a pictage type thing of how things can be going so well, then turn bad so quickly .
It started out well.. I bought my supplies.
Time to try out paint remover.. Never used the stuff before. As soon as I finished spraying it, I took the following pics.. AWESOME STUFF!!!!
OH yeah!!! Things are going niceely.
Just using the hose, it comes off this easy...
And finishing sparying it..
Sweet, this is going good.
Time to wash it off with some dawn to remove any oils and whatnot.
Now, I had to wait for it to dry.. So, I decided to play with some old wheels Andrew has...
Before spray...
After spray.. Sick
and after a quick spray with the hose..
Sweet
OK, back to the valve cover.. It's dry now (hott day in Florida BTW)
So, I needed something to put over the letters on the valve cover, so when I spraye, I could just spray the letters and when I"m done, wipe it off nice and clean.
Not having any jelly or anything, I found some.. Lipstick!! Little did I know that this seemingly, innocent sitck of lipstick would ultimately be my un-doing......
Lipstick applied
Gotta throw the thumbs up in there
So, before I sprayed my valce cover, I wanted to see what it was gonna look like.. So I sptayed another old wheel of Andrews.
Maybe he won't mind
After painting that wheel, on my way back to my valce cover, I figured I"d take a pic of my wifes Accord and my buddy's civic..
SO I put the first coat of paint on my valve cover.
It's suppose to look liek thing.. hammered Bronze.
Doesnt look very hammered.
So I sprayed 2 moer coats on it and.. well, I just wasnt feeling it at all. SO, back to lowes I go to get some more paint. I get a much lighter hammered steel paint.
Somewhat hammered looking. Ehh, not really. But I ilked it better than the bronze-ish stuff.
SO, after 2 coats of that, it's time to remove the lipstick/p[aint from the letters on the valve cover.
Some TP to wipe it off with.
DANGER!!!! I'm an effin' idiot. Sometimes I should just stop while I'm ahead. But nooooooooooooooooooooooooooo....
So, damnit... I've messed it up. Thats ok though, I've got my handy dandy paint remover stuff! I'll just spray it, reove the paint, and re-spray it again.
WRONG!
I ran out of stuff.
<sighs>
SO.... This is what I have now
And after some more spraying..
Cliffs..
Beginning:
After paint remover:
After the bronze.
After the gray.
After I become more of an idiot.
So... yeah What can I say? I'm a n00b Something that can be so easy can turn wrong very quickly.. Always remember that when your working on a car or anything, really.
Maybe I should have just wet with the wrinkle ITR red
Enj0y!
Before spray...
After spray.. Sick
Sweet
Lipstick applied
Maybe he won't mind
WRONG!
I ran out of stuff.
<sighs>
Cliffs..
Beginning:
After the bronze.
After the gray.
Enj0y!
Re: DIY: Moon cut valve cover for GSR, ITR heads.. Very detailed! (herecomesboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herecomesboost »</TD></TR><TR><TD CLASS="quote">Yeah, I would have just sanded the letters (to remove the excess paint). Good luck with round 2 </TD></TR></TABLE>
that what i did and it came out beautiful!!
Re: DIY: Moon cut valve cover for GSR, ITR heads.. Very detailed! (climb_on)
^Thats what im going to do but I was going to paint mine wrinkle red but now that ive seen this color i think ive changed my mind... I really like how that color looks.
Re: DIY: Moon cut valve cover for GSR, ITR heads.. Very detailed! (94 IntegraLS)
Alright... After I got off work, I stopped by Discount Auto and scoped out the paint section.
I did indeed find the aircraft stripper stuff for like $6.xx, so I snagged it.
Came home (like 1 min away ) ate dinner, then went outside to try and fix my gigantic screw up.
before air craft stripper stuff:
After 10-15 mins:
I love it!
So, I came back inside and petted a cute kitten
The went back outside, loaded up the valve cover in the car and drove down to the car wash so I could use the high pressure hose to clean it up good.
Before:
After!
Look at all the paint that came off...
So, I'm back at square one Discount only had wrinkle black paint in stock, so I'm gonna call tomorrow and see if I can't get some on a truck so I can get it tomorrow and spray it at work on Wednesday, so it can cure all day in t3h sun.
Sound like a plan?
Now, I'm off to play some hAL0
After 10-15 mins:
I love it!
Before:
After!
Sound like a plan?
Re: DIY: Moon cut valve cover for GSR, ITR heads.. Very detailed! (mac_24_seven)
There's what the Moon cuts look like sitting on the head... Looks awesome. Now, the paintjob on the valve cover absolutely SUCKS.... but it'll be ok
I'll re-do that.
So, I say the measurements are good for the moon cuts!
