Dash light problem. ABS, door open, seatbelt lights only.
Ok so I bought a 94 GSR original owner all is well on the car. Before the owners sold it they got it tuned up including brakes and other small things. They said that their was no problems before they brought it in to a mechanic and upon recieving the car back they said that the lights were on for the seatbelt when your driving.
However this is not the case. The seatbelt light is suppose to be the ABS light it's just showing it in the wrong form along with other lights.
When my doors are open my ABS light is on. When I close the door it's off.
When my seatbelt isn't on it shows my door are open. When I put the seatbelt on it turns the door open light off.
My seatbelt light is always on even with my seatbelt in so I know that it is actually my ABS light.
Does anyone know how to fix this?
Thanks for any help.
Old Fart
Re: Dash light problem. ABS, door open, seatbelt lights only.
When one circuit has an effect on another circuit, [seat belt warning circuit and door ajar warning circuit] it is almost always due to a grounding issue.
I would start by checking dash harness grounds, make sure everything is plugged in properly under the dash. 94
