Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Acura Integra (https://honda-tech.com/forums/acura-integra-6/)
-   -   Crank pulley question (https://honda-tech.com/forums/acura-integra-6/crank-pulley-question-3338720/)
Scott T 07-06-2019 08:49 PM
Hello, all. I’m new here, and I need a bit of help. I have a 95 Integra, and when I turn on the AC, the two pulleys that crank the AC and alternator stutter and spin slowly, but the power steering section moves at the engine RPM speed. When I shut off the AC, the rear section of the pulley starts moving. Is this a key issue? It’s killing my battery and melting me in this hot summer sun. Any help/advice would be helpful. Thanks
zeroptzero 07-07-2019 05:18 AM
Re: Crank pulley question
the description is a bit confusing, firstly nothing on the crank pulley can move differently as it is a one piece pulley. If the pullies on the a/c and alternator move differently perhaps the belts are loose. The a/c compressor is clutch activated, when it shuts off a portion of the pulley disconnects , when it turns on a portion reconnects due to the clutch activation. . If your a/c doesn't blow cold check your belt, otherwise you likely have a low Freon condition and the system needs service , it may or may not need replacement parts but that is hard to diagnose without a professional looking at the system.
jdmark1 07-07-2019 07:44 AM
If your crank pulley is moving at different speeds for different sections then it needs to be replaced. It's supposed to be one solid piece but they can break apart.
tony_2018 07-07-2019 08:36 AM
Post is confusing, only thing I can think of is that each access. is on a different size section of the crank pulley. So some look like its spinning faster/slower than others.
wunfstgsr 07-12-2019 12:59 PM
You need a new AC clutch unit, just grab a used one at the junk yard and replace the whole AC unit. Simple swap.
