Write up for blown head gasket
Old 03-08-2009, 05:16 PM
chatman_55's Avatar
Default Write up for blown head gasket
Does anyone have a write up on fixing a blown head gasket? i have been reading and im pretty sure thats whats wrong with my car, now i just need to find out how to fix it. I am still new to working on my car but hopefully i'll be able to do it myself.
Old 03-08-2009, 06:10 PM
chatman_55's Avatar
Default Re: Write up for blown head gasket
sorry didn't put enough info. it's a 2001 b18c1
Old 03-08-2009, 06:28 PM
babiboidb1's Avatar
its not hard it just takes a while to do it. i dont have a write up but i can tell you that your gonna need Radiator fluid, SILICONE, and a new valve cover gasket and something else I FORGOT. Make sure before you start taking apart the block you disconnect the battery and get ready for the fluids to leak from the head. Ill try in get you a write up. I wonder if there a difference from changing a b18a1 head gasket and a your head gasket????
Old 03-08-2009, 06:32 PM
babiboidb1's Avatar
^^ make sure you have ALOT of ziplock bagges so you can seperate the CAM pieces, and a Perminent Marker to write the part #s. GET A REPAIR MANUAL it has a write up
Old 03-08-2009, 06:41 PM
chatman_55's Avatar
i guess i'll pick up a book sometime soon. what level of difficulty would you say this is? The most i have done is change the valve cover gasket lol. but ya gotta start somewhere right
Old 03-08-2009, 07:10 PM
babiboidb1's Avatar
Its pretty up there on top. It took me about 2 days to finish mine, but that wasnt full days maybe like 4-6 hours a day. I cleaned up all the valves and springs and pretty much the whole head. I recommend you do that too cause your heads are probley just a dirty lol. HAVE FUN good luck.
PS: if you do clean everything make sure you dont lose anything. The valve springs are held by half a clip on both sides on both sides that are a PAIN to put back in(you may need two people) youll understand what im talking about if you take the spings off
Old 03-08-2009, 07:13 PM
babiboidb1's Avatar
never mind about the clip i guess b18c1 dont have them. i loked at the pics and there not there. GET THE BOOK lol
Old 03-08-2009, 07:30 PM
chatman_55's Avatar
AWESOME! well thanks for all your input. i should be able to pull of have about 2 1/2 days of free time to pull it off in. I am going to try to coax my mechanic friend into helpin me out a bit.
Old 03-08-2009, 10:11 PM
Ricextacy's Avatar
i would resurface the head and deck the block. could have warped
Old 03-08-2009, 11:17 PM
chatman_55's Avatar
could it have already warped? right now there is a small amount of white smoke coming out of the exhaust and nothing else is really happening.
Old 03-09-2009, 12:07 AM
rallyrat427's Avatar
yes... do you really wanna do all that work over again cuz you cut corners?
Old 03-09-2009, 12:55 AM
dc forever guy's Avatar
head gaskets are fairly... shouldn't take to long but make sure you lock the cams into place i'm not sure the manual says to do so. if you don't your timing has to be redone. I changed a C1 yesterday takes about 2 hours if you've seen it before. just take your time its really simple when you get to it. let me know if you need anything.
Old 03-09-2009, 02:25 AM
K i l l a B e e.'s Avatar
changing headgasket is just a matter of taking some bolts off and removing lines.. Fairly easy, luckily we have honda's. i would imagine the head to be a bitch to put on if you dont have strong arms. good luck.
Old 03-09-2009, 02:26 AM
DB squad #282
jdmjoka's Avatar
I would suggest have honda or a shop do it if you've never done this befor. i just wouldn't risk anything man. one slight wrong move.... ya know imo.
TravisCadello
17
04-10-2009 11:29 PM
headpot420
12-27-2008 12:52 AM
da_33
01-11-2007 11:12 AM
DelSol-B-18
04-08-2005 06:46 AM
Quick Reply: Write up for blown head gasket
