Coolant fan switch help
Hey all, I just got a '90 Integra from my sister for a steal. It's in relative good shape, but it's got it's share of small mechanical problems. But to the most immediate problem first.
I thought I needed to replace the coolant fan switch, but when I found the switch I realize that the mechanic who had been working on it forgot to plug it back in. Now I can't find the wiring for the switch and so can't trace it back to either radiator fan. Does anyone know which fan the coolant switch would have been wired to, if not both? I have a feeling it's the passenger side fan because sometimes it doesn't come on, though that could ben an entirely different issue. But some help would be appreciated. |
Re: Coolant fan switch help
My 90 Integra LS has the coolant fan on passenger side and ac fan on drivers side. Looking down at it on the top left side there are 2 green plugs. One is for the coolant fan hook up. You should be able to just trace the wires back from the fan itself. It's only about 6 inches to the green plug.
Thanks mate, but as it turned out I was partly right and wrong. The engine in my 90 Integra came out of a Civic, so the coolant fan switch I found that wasn't hooked up wasn't the one I was supposed to be looking for. But thanks
