Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Acura Integra (https://honda-tech.com/forums/acura-integra-6/)
-   -   check engine light P0441 (https://honda-tech.com/forums/acura-integra-6/check-engine-light-p0441-918468/)
ckyguy Jul 7, 2004 02:26 PM
ok i just ran that computer thing on my gsr for when your check engine light is on (i don't know what it's called), and it tells me the "Evaporative Emission Control System has Incorrect Purge Flow." so what do i do to fix this? replace purge valve? how? or does this thing just happen once in a while and go away after you start it like 40 times or so?
gsrboi80 Jul 7, 2004 02:47 PM
Re: check engine light P0441 (ckyguy)
I think that might be the code for when you dont tighten your gas cap tight enough. I got a cel once right after I got gas. I wasnt able to run the code but the dude at acura told me to re tighten my gas cap and it will go away in a couple of days. It went away the next day. It hasnt happened since
JimBlake Jul 8, 2004 04:11 AM
Re: check engine light P0441 (gsrboi80)
A loose gas cap should throw P1456. But still, you could reset your ECM & see if it comes back.
