Change drain plug and washer or just the washer?
When you change your oil is it necessary to change both the plug and washer or just the washer? Also would a Honda dealer carry the washer for a 00 LS (B18B)? Knowing some of their stuff is proprietary.
Re: Change drain plug and washer or just the washer? (Rick)
just the washer (every once in a while is fine). replace the bolt if for some odd reason the bolt threads are messed up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rick »</TD></TR><TR><TD CLASS="quote">Would Honda carry that washer? The Acura dealer is all the way across town.</TD></TR></TABLE>
just ask for a civic crusher. some dealers give them for free, some charge 30-40 cents or so.
I'm sure most all Hondas use the same oil drain bolt (don't see why they wouldn't). I used to buy OEM Honda filters from a Honda dealer and they always gave me a drain bolt washer along with it.
Re: Change drain plug and washer or just the washer? (JimBlake)
over 100k miles on my car and i have done a oil change every 3,000 miles and i'm still on the stock washer (no leaks)
just the washer needs to be changed every oil change.. u may wanna invest in one of those magnetic drain bolts otherwise.
jdmspoonitr
03-03-2020 06:44 PM
