Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Acura Integra (https://honda-tech.com/forums/acura-integra-6/)
-   -   CEL Code 65... (https://honda-tech.com/forums/acura-integra-6/cel-code-65-a-715777/)
BigBoyJohn Dec 26, 2003 11:20 AM
CEL Code 65...
I got a check engine light and checked what code the ecu was throwing out. It was a code 65. So I did a search and saw that a code 65 is secondary o2 sensor. I also found that the secondary o2 sensor's purpose is to see if the cat. conv. is functioning properly. Well, I recently had an emmissions test and passed (Illinois). Does anyone know why I might be getting this CEL and is the only way to shut it off, to "trick" it? BTW its a 98 ITR. TIA.
usdm420 Dec 26, 2003 11:26 AM
Re: CEL Code 65... (BigBoyJohn)
check your secondary o2 sensor
BigBoyJohn Dec 26, 2003 11:27 AM
How would I know if it is messed up?
usdm420 Dec 26, 2003 11:34 AM
Re: (BigBoyJohn)
probably cuz yer ecu is telling you its bad.
BigBoyJohn Dec 26, 2003 11:35 AM
But is there a way to see if it's bad just by looking at it?
