Can someone identify this sensor on intake manifold ?
Finishing up my b20 swap with b18 intake manifold . I have harness all hooked up except this small black sensor on right side of intake manifold on the top . Can someone explain what this is ? Is it not used with my swap ? Thanks guys
http://i57.tinypic.com/34p18d0.jpg |
Re: Can someone identify this sensor on intake manifold ?
Evap purge, if you're using an obd1 ECU you can delete it or leave it hooked up either way.
Awesome . That's what I needed to know thanks man . Using obd1 p75 ecu . Your saying just leave it the way it is ? I don't have a plug on my harness to plug into it .. Will I get a CEL ? Thanks
You won't get a check engine light on OBD1 for it
Looks clean! If you ever want to do headwork, try and find a JDM P8R head to build up. Bumps up non-vtec intake valves from 31mm to vtec sized 33mm. Rare, but worth looking for...
Sick valve cover dude
