cable tranny problems
Well last year i blew my integra tranny up. Well i bought a gsr cable tranny and bought a new clutch and act streetlite flywheel. Well when i got it all put together it wouldnt do anything the tranny was stuck in gear and wouldnt come out and wouldnt even roll in nutrual. Well when i went to put it on a trailor it became unlocked and would roll then. Well now i havent been able to work on it latey but the last time i did it would go into gear when not started and would start jumping forward with it in gear when i bumped the starter but when i took it out of gear and started it with the clutch in and then put it in gear it wouldnt go into gear all the way and i pushed as hard as i could and when i let off the clutch it would just make a grinding sound. I have tryed everything i know of and have adjusted the cable up and down and still does the same thing like its not enganging . I have a spare gsr tranny cause i know somthing is bent. I think it is either the shifter rod or the shifter fork. What do yall think and is this somthing i can fix myself or need to let and expert fix. Sorry for the long post. Sorry about the spelling too
Modified by blueintegra90 at 2:19 AM 2/11/2004 |
Re: cable tranny problems (blueintegra90)
Make sure your clutch cable is in good shape, something similar happened to me....
http://www.imagestation.com/picture/...f/f9b5197d.jpg |
Re: cable tranny problems (EL Vap133)
yea i checked the cable and also the pedal is real stiff i dont know if its from the new clutch or if that has somthing to do with it. Also is there anyway i could ave put the disk in backwards
up u go
up. does anyone else have an idea besides the cable and clutch
| All times are GMT -8. The time now is 04:07 PM. |
